Honda city express losing power
JohanR
PostPosted: 19:23 - 31 May 2012    Post subject: Honda city express losing power Reply with quote
It's not like it had a lot to start with...
It's been running fine since I've had it, about 8 months. On the way to work this morning it got about 4 miles into the 8 mile trip and then sporadically lost a bit of power. Never really enough to show on the speedometer, and would recover after a few seconds.
On the way back it was doing it from cold. It felt very sluggish to accelerate, and couldn't get above 25 mph. It can usually get to 30, at least on the flat.
I did wonder if it was one of the brakes applying itself. the front drum was cool after the trip, and the back slightly warm. I don't know what it's usually like, and it is right next to the exhaust...
What should I check, starting with the easiest, and hopefully, most likely.
I'm a complete novice when it comes to vehicles. This might be a good place to start learning.
(I found the spark plug, but have no spark plug spanner to extract it. I'll have to get one first thing tomorrow. Once I've done that, I'm out of my comfort zone!)
andys675
PostPosted: 19:27 - 31 May 2012    Post subject: Reply with quote
probably a build up of carbon in the exhaust
JohanR
PostPosted: 20:42 - 31 May 2012    Post subject: Reply with quote
The exhaust is now off.
From looking at other threads de-carbonising it is basically a case of filling it with a solution of caustic soda overnight. Apart from being careful with the caustic, are there any subtleties I missed?
Martay
PostPosted: 15:11 - 01 Jun 2012    Post subject: Reply with quote
Id certainly try a new spark plug. Might be worth cleaning the air filter too if you're de coking the exhaust.
They are quite sensitive to compression, there's not alot to begin with, which is a sign engine wear could be setting in.
Check the condition of the auto choke pipes around the carb. They're hidden from view and i found mine runs like a dog with them disconnected. there is a small rubber round filter in amongst those pipes, open it up and bin the tiny piece of foam. It seems to choke the auto choke!
Eat well, poo hard Very Happy
Drives: Cavalier 2.0 16v
Tbag
PostPosted: 16:48 - 01 Jun 2012    Post subject: Reply with quote
I had this kind of problem with my Old CG,
It was almost like i was running with the choke on.. No power whatsoever (No that it had any to start with Laughing )
I ran some redex through it and added a fuel filter, It runs fine now.
JohanR
PostPosted: 10:29 - 02 Jun 2012    Post subject: Reply with quote
Exhaust filled with caustic soda overnight, and emptied this morning. Lots of lovely black gunk came out.
There's some water still inside, not much, but I haven't been able to tip it out yet. How important is it to get it all out? Will it be expelled by the exhaust, or will it sit there and rust?
I'll clean out the air filter next.
Spark plug on order, here's the old one:
https://stampsworkshop.co.uk/misc/bike/spark_plug.jpg
According to the book, it's the right colour. The insulator appears to be missing a bit at the tip though.
Redex... Seems to be split opinions about this, but by all accounts it won't do any harm. I'll try that after the spark plug.
JohanR
PostPosted: 10:22 - 04 Jun 2012    Post subject: Reply with quote
It actually worked, the bike is working as well as it ever did. I wasn't really expecting that.
I did over torque one of the bolts holding the side panels on, and snapped the head off when putting it back together. Time to buy a bolt extractor...
PostPosted: 15:41 - 04 Jun 2012    Post subject: Reply with quote
Welcome to Yak shaving, want to clear your exhaust and end up buying bolt extractors Smile
Yak Shaving is the last step of a series of steps that occurs when you find something you need to do. "I want to wax the car today."
"Oops, the hose is still broken from the winter. I'll need to buy a new one at Home Depot."
"But Home Depot is on the other side of the Tappan Zee bridge and getting there without my EZPass is miserable because of the tolls."
"But, wait! I could borrow my neighbor's EZPass..."
"Bob won't lend me his EZPass until I return the mooshi pillow my son borrowed, though."
"And we haven't returned it because some of the stuffing fell out and we need to get some yak hair to restuff it."
And the next thing you know, you're at the zoo, shaving a yak, all so you can wax your car.
The last post was made 14 years, 163 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.04 Sec - Server Load: 0.99 - MySQL Queries: 13 - Page Size: 58.44 Kb
