| nathan k |
 nathan k Spanner Monkey
| nathan k |
 Posted: 22:06 - 09 May 2012 Post subject: |
| cb1rocket |
 cb1rocket World Chat Champion
 Posted: 22:42 - 09 May 2012 Post subject: |
putting new clutch plates on isn't going to solve it, you did realise that?
Sounds like the clutch shaft is snapped if its not pushing out the other end. It can't be properly tested unless the whole engine is put back together and checked properly. I think the engine covers serve a purpose with the clutch but can't see well in your video |
| nathan k |
| mad4it028 |
 mad4it028 World Chat Champion
| karthead |
 karthead Trackday Trickster
 Posted: 06:54 - 10 May 2012 Post subject: |
Hmmm. on my KE125 engine, there is a pushrod that goes through the engine and pushes against that other rod with the plate (which pushes the end clutch plate out) thats shown in the video. Between the pushrod and that rod/disc thingo, there was a little 7/32 ball bearing that wasnt there before, so i bought one which increased the distance that end disc moved when disengaging. have a look at your pushrod (if there is any). if it has an end where it is curved inwards to fit a little bearing ball, then ball is what's probably missing.
best of luck  |
| nathan k |
| MaybeGuy |
 MaybeGuy Super Spammer
 Posted: 21:03 - 31 May 2012 Post subject: |
5mm is probably too small. The ball bearings used tend to have a diameter equal to the pushrod. ____________________ Blue_SV650S wrote: it was a sh1te wheelie, but it proves that he can get it up in 3rd and can do angles. In summery, mattsprattuk is a gobby little sh1tebag, dopehead tw4t, but sadly for all of us, he probably isn't THAT full of sh1te!!
| nathan k |
| MaybeGuy |
 Posted: 21:32 - 31 May 2012 Post subject: |
Where are you putting the ball bearing? and are there 2 pushrods? ____________________ Blue_SV650S wrote: it was a sh1te wheelie, but it proves that he can get it up in 3rd and can do angles. In summery, mattsprattuk is a gobby little sh1tebag, dopehead tw4t, but sadly for all of us, he probably isn't THAT full of sh1te!!
| nathan k |
| MaybeGuy |
 Posted: 21:46 - 31 May 2012 Post subject: |
Is there a screw with a locknut in the middle of the pressure plate? ____________________ Blue_SV650S wrote: it was a sh1te wheelie, but it proves that he can get it up in 3rd and can do angles. In summery, mattsprattuk is a gobby little sh1tebag, dopehead tw4t, but sadly for all of us, he probably isn't THAT full of sh1te!!
| Pete. |
 Pete. Super Spammer
| MaybeGuy |
 Posted: 21:54 - 31 May 2012 Post subject: |
Still counts as mine, sniping bastard. ____________________ Blue_SV650S wrote: it was a sh1te wheelie, but it proves that he can get it up in 3rd and can do angles. In summery, mattsprattuk is a gobby little sh1tebag, dopehead tw4t, but sadly for all of us, he probably isn't THAT full of sh1te!!
| nathan k |
 Posted: 22:18 - 31 May 2012 Post subject: |
Thanks lads, will try adjusting it tomorrow, last time I tried the nut wouldn't budge so I'll try taking it off and putting in a vice to get a better grip. |
The last post was made 13 years, 261 days ago. Instead of replying here, would creating a new thread be more useful? |
