Brake fluid.
map
Mr Calendar
PostPosted: 01:12 - 01 Jun 2012    Post subject: Re: Brake fluid. Reply with quote
_Iain_ wrote:
...how do i get brake fluid off the tyre? ...
Try brake cleaner fluid.
weasley
PostPosted: 06:30 - 01 Jun 2012    Post subject: Reply with quote
Coppaslip ONLY on the FACES of the pistons, or the back of the pads, NOT on or near the piston seals or caliper bores. IF you must grease the seals, use rubber grease only. Or leave them dry.
DrDonnyBrago
PostPosted: 07:58 - 01 Jun 2012    Post subject: Re: Brake fluid. Reply with quote
Pump the pistons out nice and far, use a block of wood /something not metal to block the freer moving pistons if you need to get more than one piston out. Use only brake fluid, or red rubber grease on the pistons and seals themselves.
The important thing is to check the condition of the seals and clean the crap that has inevitably built up in the seal groove out with something soft (wood/plastic, no metal). You can wash the caliper in soapy water, rinse it thoroughly and dry it in the oven on low heat if you need to get a particularly stubborn bit out.
Copper grease on backs of pads (thin smear) and a bit on pad pins if you like. It's a suzuki so copper grease pad retaining pins to stop them seizing. Loctite threadlock the caliper holding bolts.
Soap and water will get the brake fluid off your tyre. If you get any on paint, wipe it off quickly with a wet rag.
Tbag
PostPosted: 20:21 - 01 Jun 2012    Post subject: Reply with quote
_Iain_ wrote:
Next question,
Have replaced the seals, all the fluid, pads (ebc HH sintered) and still spongy as. The line looks a bit iffy, very old a little perished. It bulges slightly when i apply the brakes. Brakes are 100% bled, no leaks, good pads, good fluid and still feel a little unresponsive and spongy...
I'm assuming new line required, if so braided or standard? Pros/cons.
Oh and the fairy liquid/scrubbing brush combo worked beautifully! Thumbs Up Karma
Aye, It sounds like the lines are expanding under pressure..
Get some braided ones, They look cooler, last longer and are better!
PostPosted: 20:44 - 01 Jun 2012    Post subject: Reply with quote
Possibly. However make triple sure you have bled the brakes through. Easy to land up with an air bubble at the top banjo bolt (for example).
If you do replace the line then you may as well use a braided hose, as they are a fair bit cheaper normally. Down sides of them is that they are more easily damaged / more easily damage things by rubbing. Also they are more rigid so harder to route.
The last post was made 13 years, 266 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.58 - MySQL Queries: 13 - Page Size: 58.16 Kb
