| map |
 map Mr Calendar
 Posted: 21:23 - 25 May 2012 Post subject: Bike being stood - what next advice * DONE and WORKING * |
A mate's ST1100 has been stuck on his drive for some time. Judging by the last tax disc that'd be quite some time, Anyhow it was in gear. A group effort has just managed to get it nto neutral.
Given bike stoop for so long what's the next steps?
Bike not started.
Thanks in advance.
 ____________________ ...and the whirlwind is in the thorn trees, it's hard for thee to kick against the pricks...
Gibbs, what did Duckie look like when he was younger?
| Suntan Sid |
 Posted: 21:36 - 25 May 2012 Post subject: |
Change all fluids, check all fluid pipes for leaks, might be tempted to dribble a bit of oil down the bores before you turn the engine over.
Clean carbs, petrol tank and filters.
Might want to turn the engine over by pushing it along, slowly, while in gear, before hitting the button. ____________________ "Everybody needs money, that's why they call it money!"  |
| Walloper |
 Walloper Super Spammer
| temeluchus |
| Casper |
 Casper World Chat Champion
| Walloper |
| Casper |
| stevo as b4 |
| map |
 map Mr Calendar
 Posted: 19:54 - 27 May 2012 Post subject: |
Thanks guys for the advice.
More or less as I thought but nice to get a consensus and 2nd opinion.
Nice heads-up about the rubber hoses and connections. Not sure if it has braided brake hoses but this might be a chance to check and change if needed. Will check all the other rubbers. I imagine the air box will be a pain (but aren't they always regardless of bike! )
All oil will be dropped and replaced. Might only be with cheap stuff first as once proved running then it will get another fresh batch.
Dropping fuel will be interesting as the fuel tank lives in the belly of the beast. The big tank thingy on them is for the car sized air filter above the carbs. It keeps the centre of gravity lower, which on something like this has to be a good thing. So in order to take out the fuel tank it looks like a lot of dismantling need to take place.
Have to declare an interest as if this bike works I'll be taking it. So want to get it on the road for as little as possible (I'm tight like that ).
At the moment trying to get all the panels off to make like easier*. It can get through an MOT without panels just have to make sure all the electrics, brakes, indicators, etc. are in place and work. I've fought with VFR panels before but whoever designed the Pan-European was evil. I may start another thread on this as having major problems.
Thanks again and I'll post of progress.
*This is because in order to get at the back spark plugs you need the articulated plug socket that's in the OEM toolbit. Luckily bike still has it. No other tool will do with panels in place . ____________________ ...and the whirlwind is in the thorn trees, it's hard for thee to kick against the pricks...
| bikenut |
 bikenut World Chat Champion
 Posted: 12:37 - 28 May 2012 Post subject: dormant bikie |
:karma: hi dude,
all of the above but turn engine over slowly by hand with plugs out first, valves can and do stick ( open usually ).
if engine turns over ok by hand ( you can see the valves thru the plug holes usually ) whiz on starter.
after sure oil got to all engine bits, so everything nicely lubed, then try to start.
leave running on centre stand to check for leaks etc.
the clutch will probably be stuck, so leave on stand and allow to warm up properly. when hot, use clutch lever and listen to g/box noise..........does g/box noise stop meaning clutch free????
after warm up on stand, stop engine, select second gear and start engine, allow to run and hold in clutch.......use throttle to make transmission snatch, to snatch clutch free when engine hot.
do not just open the throttle, smash it into gear and fuck the box.......
alternatively, strip and clean the clutch, whilst there flush out the crank case.......clutch debris and sediment etc....... |
| Walloper |
| Marmalade |
 Marmalade World Chat Champion
 Posted: 21:06 - 29 May 2012 Post subject: |
If it refuses to turn over and won't turn the engine by pushing it in gear then the alternator will be corroded, probably cracked and you'll need £300+ deep pockets to get another one.
This is if you want to remove the rear wheel, tank, bevel unit, rear subframe and a few other bits and pieces to be able to access it. ____________________ Nobby the Bastard: How yo tell the difference between the actual japanese and her just screaming because she's had live fish stuck up her arse? [url=https://www.nicks-shop.co.uk/bcf-goodies-15-c.aspGet BCF stickers and things here[/url] Reflective helmet stickers - Legal requirement in france - Clicky |
| map |
 map Mr Calendar
| Lone-Wolf |
 Lone-Wolf World Chat Champion
 Posted: 12:34 - 01 Jun 2012 Post subject: |
Wotcha.
I've just made a start on a bike that's been standing . . . . for the last forty years. The fellow bought it new, rode it to work for four years, then emmigrated to Australia leaving the bike behind in an outbuilding at the local pub. That was the last time it was taxed and tested.
https://www.moonshiners.org.uk/D144S/144stax.jpg ____________________ Cheers.
L.W. - www.moonshiners.org.uk |
| Walloper |
| Lone-Wolf |
| Walloper |
The last post was made 13 years, 255 days ago. Instead of replying here, would creating a new thread be more useful? |
