| HD |
 HD World Chat Champion
| DrDonnyBrago |
 Posted: 23:35 - 01 Jun 2012 Post subject: Re: Helicoils and exhaust studs |
| HD wrote: | Basically a while back I stripped the thread on one of the exhaust manifolds. I used the bolts on the bike and tightened them up too much and yeah, you know the rest.
Now where can I buy a helicoil kit, what does it comprise of, do I need any other tools and how much is it?
Also, would exhaust studs be more beneficial for me? If so, how do I go about it? I'm guessing buy a large length of threaded bar, cut it to length and wind it in? But how do I tighten it up?
Thanks |
Helicoil kit can be bought online, the kits come with everything except for a drill. Check eBay for a kit in your thread size (probably M8).
As for the studs, you can use threaded rod but I tend to use proper studs. Not sure why you shouldn't use the rod, part of me says that the rounded bulbous part of the studs protects the thread against water ingress but that is probably bullshit. Whatever you use, it doesn't need to be in tight (finger tight is enough), when you put the nuts on and clamp it down the tension will hold them in place. The reason you stripped the thread is because you used bolts which do need to be tight and place a lot of stress on the threads of the cylinder head - it's why you should use studs in the first place .
Use plenty of copper grease on the studs and if I were you I'd also use brass nuts. The brass nuts will strip before the studs snap if they ever manage to get corroded in place again. |
| HD |
| orac |
 orac World Chat Champion
 Posted: 07:02 - 02 Jun 2012 Post subject: |
https://www.machinemart.co.uk/shop/search/filter/armacoil/type/any/page/1
i used one to repair thread in a cranckasem dunno if they still come with it but mine had the correct drill too ____________________ Current rides - 2016 Triumph Street Triple Rx, 1994 Suzuki Bandit 400 VM, TGB 204 Classic 125cc
"with nothing left to lose, there is everything to gain. It's not the size of the dog in the fight, it's the size of the fight in the dog" |
| Serendipity |
 Serendipity World Chat Champion
| DrDonnyBrago |
| HD |
The last post was made 13 years, 267 days ago. Instead of replying here, would creating a new thread be more useful? |
