cg 125 wiring
mwnci
PostPosted: 13:04 - 05 Jun 2012    Post subject: cg 125 wiring Reply with quote
Im new to this forum so first of all a hello to fellow bikers! not only am i new to the forum but also biking, and therefore have very limited knowledge.
I was mystified though as to why i only have 4 wires coming from the flywheel generator, there is a pink wire missing, should i be worried? is this important? I have a hundred other questions as im currently trying to figure out the wiring loom but thought I would start with one simple question and see what sort of response im likely to receive. help would be very much appreciated though, since i have no biker buddies to steer me in the right direction, im enthusiastic to learn tho cos i wanna get this bike back on the road!
cheers
badluck
PostPosted: 14:05 - 05 Jun 2012    Post subject: Reply with quote
Hi Smile
I registered just to answer your question! And I do believe I will need some help myself shortly :p
I'm currently constructing a CG125 Chinese clone, but I am led to believe that the wiring loom and parts are interchangeable... (correct me if I'm wrong?)
I have been posting in another forum and have been helped greatly in regards to wiring! Link is here .
More specifically, if you cannot view the forum, part coloured wiring diagram is here .
Good Luck Smile
mwnci
PostPosted: 14:39 - 05 Jun 2012    Post subject: Reply with quote
hi, thanks for the reply, but i don't think it does answer my question because thats the wiring diagram for a huoniao bike, whereas i have a honda CG125-C that doesn't even have a CDI unit. I was wanting to know whether a missing wire from the generator was something to worry about. Im thinking it doesn't because it seems to be a switch from daytime to night time setting whatever that means. but that leaves me with a wire from the lighting switch unconnected so is that a break in the circuit? now i wish i listened more learning about circuits at school.
As for the interchangeability of parts, yes i think you can just wire a bike how you like as long as you know what your doing; my problem is, i don't. but i can learn Smile hopefully
J.M.
PostPosted: 15:23 - 05 Jun 2012    Post subject: Reply with quote
According to the wiring diagram (linky), you should only have Yellow, White and Black & White coming from the Flywheel generator.
The flywheel generator should also be grounded.
2004 R1 & 2018 XSR900
U_W v2.0
PostPosted: 16:45 - 05 Jun 2012    Post subject: Reply with quote
badluck wrote:
Hi Smile
Good Luck Smile
LOL thats MY wiring diagram. i went over it in paint lol. i'll be completing it at some point lol
badluck
PostPosted: 17:12 - 05 Jun 2012    Post subject: Reply with quote
That is your wiring diagram! Smile
I didn't realise you were on here too otherwise I would have given you credit Smile
Thanks for assisting with resolving my confusion too Smile
mwnci
PostPosted: 18:42 - 06 Jun 2012    Post subject: Reply with quote
thanks for the response JM but thats a later model, i was hoping to wire it exactly the same as the C model (1983) which seems to have less parts i.e. no CDI unit. but also according the that diagram it should have 5 wires coming from the generator: Lg R, Bl W, W Y, P and Y. Mine bikes missing the pink wire, is that important? kind of wish i had a scanner so you could see how it should be. it should connect to the lighting switches where there is a pink wire left unconnected.
Hope you can understand my descriptions because im not too clued up on the technical lingo
The last post was made 14 years, 160 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 0.25 - MySQL Queries: 13 - Page Size: 52.77 Kb
