suzuki gz 125
poohbah68
PostPosted: 21:00 - 15 Aug 2010    Post subject: suzuki gz 125 Reply with quote
slow on changing gears,looses power rapid up hills,have changed spark plug and oil filter,any suggestions welcome
mart
cb1rocket
PostPosted: 22:06 - 15 Aug 2010    Post subject: Reply with quote
clogged up air filter
radical
PostPosted: 22:45 - 15 Aug 2010    Post subject: Reply with quote
Is there any oil in the bike or could the oil be very low.
The Original Muzza
PostPosted: 00:07 - 16 Aug 2010    Post subject: Reply with quote
What sort of power loss you getting up hills? I'm lucky to get over 55 on a medium gradient in 4th gear and getting there is not easy either. It's just not a powerful bike.
As for the gears, has it been sitting a while? A change of oil should see improvements as it did when I had gammy gear changes on mine.
If after oil change it's still noticeably less powerful than before, try cleaning out the carbs/injectors as well. Luckily quite a simple bike to fiddle with, unless all your screws etc are rounded off/seized. Evil or Very Mad
poohbah68
PostPosted: 05:51 - 16 Aug 2010    Post subject: Reply with quote
was sitting for 2 week, thought it might need a good run when i got back, it dwindles down to Rolling Eyes 8mph up hills,so il try everything on your replies, thanks
mart
The Original Muzza
PostPosted: 11:57 - 16 Aug 2010    Post subject: Reply with quote
8mph? Laughing That is indeed cause for concern.
Have you checked chain tension as well? Best to check over the bike thoroughly now for all the simple stuff. Do you have a manual for the bike (I know the haynes one is focused on the GN, but has enough on pre-2006 GZ that it's actually quite useful).
poohbah68
PostPosted: 07:34 - 21 Aug 2010    Post subject: Reply with quote
all fixed thats guys for your help Surprised
mart
poohbah68
PostPosted: 21:06 - 22 Aug 2010    Post subject: Reply with quote
too much oil went into the air filter moving from level road to a hill,never make that mistake again ,carb needed a good clean as lots of crap in there,the chain had too much tension.
anyways i was helping my sister move and found an old maintenance manual and instruction book for the unapproachable Norton models 16H,big 4, 18 & ES2 it cost 1 shilling was wondering what year it was, also there was a motor cyclists workshop by torrens of the motorcycle 1947 there a bit tatty but all the pages are there
mart
There is a gap of 1 year, 287 days between these two posts...
alexknight200...
PostPosted: 17:50 - 05 Jun 2012    Post subject: How often do you change your air filter Reply with quote
Hi,
How often do you change your air filter. Mine was last changed march 2009.
Also can you just clean it rather than replace it Question
Alex
Current stable: Yamaha XVS 650 1996 - Honda Super Magna VF750 1988.
The Artist
PostPosted: 17:53 - 05 Jun 2012    Post subject: Re: How often do you change your air filter Reply with quote
alexknight2000 wrote:
Hi,
Alex
https://images.retecool.com/uploads/shabaz-holy_thread_resurrection_batman.jpg
alexknight200...
PostPosted: 17:58 - 05 Jun 2012    Post subject: sorry Reply with quote
Hi Sorry,
I was searching the forums to see of the topic had already been covered but could only find this Embarassed Thinking
cb1rocket
PostPosted: 19:11 - 05 Jun 2012    Post subject: Reply with quote
yes just soak it in oil and give it a squeeze. and replace
Instructions for this are in the owners manual
The last post was made 14 years, 161 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.04 Sec - Server Load: 0.25 - MySQL Queries: 13 - Page Size: 81.69 Kb
