| RossShort |
 RossShort L Plate Warrior
| Casper |
 Casper World Chat Champion
| RossShort |
| Casper |
| Teflon-Mike |
 Posted: 16:09 - 08 Jun 2012 Post subject: |
The top-yoke is likely to be rather un-helpful. On Snowie's AJS when I had a shuftie it was a VERY cheap and spindly zinc-alloy casting, that was almost paper-thin with loads of cross-webbing, like a moulded plastic milk-crate.
I would NOT want to drill one to take bar-clamps, as there is just NOT the metal there to support it, and the metal itself is NOT particularly strong... stuff they make match-box toy cars from!
That gear-lever; could be taken off and straightened by some-one with a gas-torch and a vice.
Clocks, personally I would either get something off an old Honda and cobble to fit; looks like a lot of Honda 'equipment' is used on teh AJS's... certainly was on Snowie's.
CG125 or CB125 'dash' would probably bolt straight on & plug into the loom, & the speedo calibration even be the same. If not AJS dials would probably go into the Honda Box.....
I conventeiently have a few Honda dash's knocking around, so I would be looking to see what I could do with soldering iron, plastic welding, glue and mix of bits. ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
| Casper |
| Teflon-Mike |
 Posted: 18:45 - 08 Jun 2012 Post subject: |
| 1888 wrote: | Are the yokes that shit on them? You could get the type that clip on the top of the forks but you will need to drop the front end an inch to fit them. |
Top yoke on most bikes, isn't hugely sturdy, TBH.
FJ1200? - Pretty '#Beefy' bit of iron-age engineering. Was looking at yoke on one of them with Jimbo, thicker webbing, and better metal, but same problem; there's not enough 'meat' in it to drill into and make a secure mount.
Look at yokes with propper bar-clamps, either intehrally cast, or they are drilled into a 3/4" 'slab' thats relieved only where the boss holes aren't.
Yeah, seen it done, seen it done well, but more often badly; its not a practice I would suggest to a 'newb' who probably only has a vague idea about it, and 'it makes sense' and goes off, and drills holes, taps them, then maybe even grinds away webbing to get a bolt on the back when the bar-clamps start wobbling.... or worse... starts trying to gob it up with 'metal-set'!
If you want conventional bars, there are yoke-kits, that will bolt on on place of the clip-on...
Alternatively.... my motto.... if it ent broke, dont fix it!
Especially when there's other stuff that IS broke and needs fixing! ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
| Casper |
The last post was made 14 years, 159 days ago. Instead of replying here, would creating a new thread be more useful? |
