clutch not working
U_W v2.0
PostPosted: 17:06 - 08 Jun 2012    Post subject: clutch not working Reply with quote
so my clutch isnt working.
tightened up the cable at the hand lever no effect
moved the clutch arm on the engine casing all the way to the right with absolutely no effect what so ever.
so im going to remove the engine casing tomorow and have a look.
any ideas what i should be looking for?
U_W v2.0
PostPosted: 17:13 - 08 Jun 2012    Post subject: Reply with quote
how bout posting something helpful here?
further information:
the bike is up on its center stand, so the wheel spins off the ground.
the wheel speed increases when accelerator is rolled so im led to believe the clutch isnt working properly.
U_W v2.0
PostPosted: 17:16 - 08 Jun 2012    Post subject: Reply with quote
completely unlreated and unhelpful to the thread.
there fore, SPAM, like your above post is abusive and will be rated as such.
back on topic please. need help with the clutch
PostPosted: 17:20 - 08 Jun 2012    Post subject: Reply with quote
Yep... its meant to do that.
UNLESS you are holding your clutch lever in (vital info missed there)
U_W v2.0
PostPosted: 17:33 - 08 Jun 2012    Post subject: Reply with quote
sorry, yeah while holding the clutch in.
but i just made some more adjustments and it seems to be working just fine.
now i need to adjust the cable again so i got the movement in the handle lever
PostPosted: 17:34 - 08 Jun 2012    Post subject: Reply with quote
Also...it should spin in neutral.
Put it this way, if you sit on it and put it in 1st and release the lever totally and go nowhere...there is an issue.
If you release and it stalls, its fine.
Don't go by what happens on the centre stand.
U_W v2.0
PostPosted: 17:40 - 08 Jun 2012    Post subject: Reply with quote
awesome, thanks paddy, although the wheel doesnt spin in neutral.
although its a new sprocket and new chain and one of the spacers IS siezed to the axle so the difference between 1st and neutral might JUST be different enough to make it spin in 1st with clutch in and neutral
The last post was made 14 years, 159 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.04 Sec - Server Load: 0.36 - MySQL Queries: 13 - Page Size: 59.49 Kb
