Please can someone help me with my Honda cg please!!!
Cgiow
PostPosted: 18:31 - 09 Jun 2012    Post subject: Please can someone help me with my Honda cg please!!! Reply with quote
Hello my names Martyn I have a 1996 Honda cg alittle wile ago I went through a puddle/pond :-/ and ever since she's been back fireing and juddering a lot and not running how she used to:-/ I got her a new exhaust and shocks, the air filter is damp but i don't think it's that?, I have taken the carb to pieces cleaned it all with cotton bud and air blower thingy lol, also emptied the fuel tank cleaned the fuel filter, she ran ok for abit turned her off and a hour or so later she was running bad again I'm getting a good enough spark and oil is ok got a full tank of fuel, don't think brake pads are rubbing although I did fit new ones last week but I'm sure it's not that, as I say she's popping and back fireing when I speed up and let the throttle go she does it, and iv done what I can think of and I'm now baffled :-/ can anyone help!! And I'm not sure about how the screws on the carb should be ? Can some one help Smile
M l poskitt
Usher4566
PostPosted: 18:34 - 09 Jun 2012    Post subject: Reply with quote
Wats spark plug colour.pic ?
New cd200 benly owner
Usher4566
PostPosted: 18:35 - 09 Jun 2012    Post subject: Reply with quote
Air filter damp ? With water ? Oil?fuel ?
Cgiow
PostPosted: 18:41 - 09 Jun 2012    Post subject: Reply with quote
I think it's water it does not smell like petrol much only a tiny bit And I'll try to upload pic soon
M l poskitt
Usher4566
PostPosted: 18:47 - 09 Jun 2012    Post subject: Reply with quote
Probs your problem if its water it will restrict air flow make yourbike run rich and soot your plugs up and cause backfire .air filter should be little moist with oilbut not water.
Cgiow
PostPosted: 19:21 - 09 Jun 2012    Post subject: Reply with quote
Plug pic
M l poskitt
U_W v2.0
PostPosted: 19:38 - 09 Jun 2012    Post subject: Reply with quote
you need to use the macro setting on your camera for close up shots like that.
even camera phones have a macro setting, just FYI lol
Cgiow
PostPosted: 19:54 - 09 Jun 2012    Post subject: Reply with quote
Iv just looked and i belivre there is water/condensation in my engin as the pipe/over flow is dripping a small amount of water ? Any ideas
M l poskitt
Usher4566
PostPosted: 20:16 - 09 Jun 2012    Post subject: Reply with quote
Looks like its black to me .running rich hard to tell on thY pic .check and renew air filter replace plug
Usher4566
PostPosted: 20:22 - 09 Jun 2012    Post subject: Reply with quote
Robby
Dirty Old Man
PostPosted: 21:05 - 09 Jun 2012    Post subject: Reply with quote
If the air filter is damp, that needs sorting. If it's a removable foam element, wash it in petrol, let it dry, then lightly oil it. If its a paper element then replace it.
You could try snipping a bit off the HT lead, but you might as well just replace it. HT lead is cheap and you only need a few inches.
Cgiow
PostPosted: 21:26 - 09 Jun 2012    Post subject: Reply with quote
Better pic i hope but there is also little drops of water comming out of the pipe fron the engine Sad
Usher4566
PostPosted: 21:40 - 09 Jun 2012    Post subject: Reply with quote
Lol that's better but we want to see it face on so can see electrobe Ect but it deft black is it sooty black ? But from look of it that plug will cause miss fire. Change it and see how it goes but I would look at air filter could be choking enging making inrun rich
Cgiow
PostPosted: 21:56 - 09 Jun 2012    Post subject: Reply with quote
Thank you everyone I'll soak the filter tomorrow, and try to get new plug as well can some1 tell me the best plug to get? Smile
M l poskitt
tomh
PostPosted: 00:30 - 10 Jun 2012    Post subject: Reply with quote
Just to explain: If your air filter is clogged with water, air will struggle to get into the carb meaning too much fuel is going to the engine but not enough air which is proven by looking at your black spark plug. Because there is to much fuel, it is going in and then out through the exhaust unburnt. The exhaust is very hot which causes it to burn when it touches the exhaust causing it to 'backfire'.
The other explanation is the spark plug/ht lead failing, which can cause the same symptoms.
I wouldn't worry to much about the water dripping out as the breather tube is doing it's job. In fact it's normal to have some water in your oil if you don't warm the bike up fully. To burn it off just get the bike to full temp. It won't hurt though to change your oil.
Cgiow
PostPosted: 08:54 - 10 Jun 2012    Post subject: Reply with quote
Ok thank you I have shortened my ht lead abit for cleaner wiring and sounds better already as its Sunday I can't get oil anywhere till tomorrow so I'll give her a oil change and new plug and air filter tomorrow if she's not any better I shall let you guys know, also tho on my carb I'm not sure where the screws should be the one under the carb I was told to tighten it up the undo it 2 full turns can anyone help Smile
M l poskitt
karthead
PostPosted: 09:10 - 10 Jun 2012    Post subject: Reply with quote
im glad everything is getting better Smile im guessing thats the idle mixture screw you're talking about.. do what you were told and undo it 2 full turns. then see how its running by doing a plug chop a idle. this means that you keep it on idle for a couple minutes then kill the ignition. take the plug out and observe the colour. probably dont do it untill you have the new filter and everything because a wet filter will probably alter results.
let us know how it goes Thumbs Up
PostPosted: 09:22 - 10 Jun 2012    Post subject: Reply with quote
If the bike was running fine before you went through a puddle, then don't touch the idle mixture screw. Why would you want to make adjustments to an engine that was running fine?
Get the air filter off and run the bike without it. If the bike now runs fine, your air filter is clogged.
If it's the foam type which you oil then getting it wet might restrict it because the oil and water will form an emulsion which will be held in the foam. To clean it, get a bucket of hot water with a good squirt of fairy liquid and wash the foam out thoroughly in the bucket, squeeze out the water and allow to dry, then re-oil, not forgetting to squeeze out the excess oil into a rag or some paper towel.
spaz
PostPosted: 09:40 - 10 Jun 2012    Post subject: Reply with quote
NOOOOOOOOOOOOO!!!
What you are referring to is the pilot jet; it controls the first 1/8th of throttle movement. As has already been said, do NOT adjust anything if the bike was running fine prior to the 'puddle' incident.
"If it's got tits or an engine, it'll be trouble"
karthead
PostPosted: 09:55 - 10 Jun 2012    Post subject: Reply with quote
spaz wrote:
NOOOOOOOOOOOOO!!!
sorry, what i was meant to say is not to change it unless it isnt running well once he has done everything. hopefully everything will be better once he has finished with the air filter and everything. if not then he should consider tuning it Thumbs Up
Cgiow
Ok so i have done the plug (not a new one yet) i mean the ht lead ill take her for a little run, just so u guys know iv had her almost a year the owner before left her in a shed for 6 ish years she only has 24000 miles in 16 years
M l poskitt
karthead
PostPosted: 09:57 - 10 Jun 2012    Post subject: Reply with quote
wouldnt taking it off make it run lean?
Cgiow
PostPosted: 10:14 - 10 Jun 2012    Post subject: Reply with quote
Ok so I'm back and quite wet lol but she is better without air filter but juddering a lot and feels like there's no fuel getting through but I ether pull throttle rite back and she goes or ease off to slow down, basicly she won't maintain speed without juddering Confused
M l poskitt
Cgiow
PostPosted: 10:17 - 10 Jun 2012    Post subject: Reply with quote
Oh and I cleaned plug before I went out and I'll upload a pic in a mo
M l poskitt
The last post was made 14 years, 121 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.91 - MySQL Queries: 13 - Page Size: 125.59 Kb
