Suspension setup....
CaNsA
PostPosted: 10:13 - 10 Jun 2012    Post subject: Suspension setup.... Reply with quote
Replaced the zxr400 rear shock last week as it had popped and pissed its fluid every where.
Banged a zx6r one in, no probs, like a glove Very Happy
There is no sag, feels a bit hard, rebounds at a decent rate.
The shock has a remote reservoir, a screw setting on the bottom of the shock with 4 settings, and obviously the spring.
Which part is for compression, pre-load, rebound?
And which should i adjust to give me a bit of sag and soften the arse a bit?
cheers peeps.
PostPosted: 11:16 - 10 Jun 2012    Post subject: Reply with quote
preload is what you want to adjust and it is usually two castellated locking rings above the spring. Just loosen the top one, and then turn the bottom one anticlockwise until less thread is showing above it, then tighten the top one. You'll need a decent 'C' spanner to do it.
CaNsA
PostPosted: 11:30 - 10 Jun 2012    Post subject: Reply with quote
Cheers MarJay Thumbs Up Karma
jay12329
Dr. Evil
PostPosted: 16:16 - 10 Jun 2012    Post subject: Reply with quote
Good bit of info on bouncy bits here;
https://www.675.cc/675/viewtopic.php?f=53&t=5979
Hth
J
jjdugen
PostPosted: 19:07 - 10 Jun 2012    Post subject: Reply with quote
There should also be an adjuster on the very bottom of the shock, this is for compression damping, try taking that to the softest and work back up.
Old Git Racing
PostPosted: 23:34 - 10 Jun 2012    Post subject: Reply with quote
Think you might find this is the rebound adjuster.
OGR
The last post was made 14 years, 104 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 0.66 - MySQL Queries: 13 - Page Size: 47.86 Kb
