Lifting a cruiser
EazyDuz
PostPosted: 18:31 - 10 Jun 2012    Post subject: Lifting a cruiser Reply with quote
Due to their awkward shape and on mine the huge shaft drive being in the way, it makes lifting the bike harder.
Im just after something which will lift the rear wheel and is able to lift the front wheel to (not at the same time) for any future work i may need to do on it.
I intend to keep the bike for a long time so may as well get kitted up with tools and stuff i might need.
Was wondering if a simple device like this would work:
https://www.ebay.co.uk/itm/Sealey-Tools-MPS2-Two-Arm-Centre-Lift-Stand-Motorcycle-Motorbike-Cruiser-Style-/360447857846?pt=UK_Motorcycle_Parts&hash=item53ec5dd4b6
Or would it be pretty crap?
McfcChris94
PostPosted: 18:46 - 10 Jun 2012    Post subject: Reply with quote
https://www.youtube.com/watch?v=3t-0-2ekA3U
Very Happy
CBT Passed; 13/05/2012
Current; Honda CG 125
fireyphoenix1...
PostPosted: 18:47 - 10 Jun 2012    Post subject: Reply with quote
cant be that crap my mates work shop has one for when he gets shit like harleys in for tyre changes it does the job lol
2014 Aprillia dorsoduro 750 factory.
growler
PostPosted: 19:09 - 10 Jun 2012    Post subject: Reply with quote
I used a 2 ton jack and 2 small axle stands
DILLIGAF
PostPosted: 20:56 - 10 Jun 2012    Post subject: Reply with quote
Use a plank of wood and a pole :-
https://www.nightrider.com/biketech/bikelift.htm
Don't even have to attach a pole, just use a bracket :-
https://www.tornbjerg.dk/hp/savagesources/tools/stand/stand3.jpg
https://www.tornbjerg.dk/hp/savagesources/tools/stand/stand4.jpg
Ichy
PostPosted: 21:35 - 10 Jun 2012    Post subject: Reply with quote
The one you linked to on Ebay works perfectly, I have a similar one.
I got this one. stand
Very cheap price but really well made and it only took a couple of days for delivery from Germany.
PostPosted: 22:27 - 10 Jun 2012    Post subject: Reply with quote
What about those flat ATV/Harley lifts? You can get the whole bike off the floor with them. I bought mine in Macros a few years back, just modified it to hold my 'busa up in the air with the suspension pulled off.
T0MMY
PostPosted: 22:45 - 10 Jun 2012    Post subject: Reply with quote
It might be possible to run the leather handlebar tassels up through a pulley if you have rafters or something in your garage to winch from Thinking
ZX6R + CBR600RR
keggyhander
PostPosted: 22:57 - 10 Jun 2012    Post subject: Reply with quote
That's what I've got. Bought it off a mate for 60 quid.
PostPosted: 23:55 - 10 Jun 2012    Post subject: Reply with quote
If you know any men, ask them to shove a block of wood under one swing arm and a jack under t'other.
EazyDuz
PostPosted: 07:17 - 11 Jun 2012    Post subject: Reply with quote
That looks good, what bike do you lift with it?
fatjames
PostPosted: 08:48 - 11 Jun 2012    Post subject: Reply with quote
Someone post a pic please. Can't get to eBay in work Thumbs Down
I was reading about the "Americana 2 bike lift" on m&p, it's about £100, however, I can't see how it works around the exhaust.
On my Virago, the front exhaust runs down and under the side of the engine.
https://www.mandp.co.uk/productinfo/548135/Workshop/Bike-Lifts/On-Two-Wheels
Views?
yambabe
PostPosted: 11:25 - 11 Jun 2012    Post subject: Reply with quote
This.
I've got one of those too, worked perfectly fine when I had to get the engine out of the VS800.
However, I also agree with the block-of-wood theory, I generally use that if I want to get a front or back wheel off the floor. Only problem with it is that it takes 2 of us.
I'm curious as to what you think you may need to do to the bike that needs it to be off the ground?
PostPosted: 11:40 - 11 Jun 2012    Post subject: Reply with quote
He needs to check the tassels are the same length and hang the same way.
Smile
Ichy
PostPosted: 12:06 - 11 Jun 2012    Post subject: Reply with quote
Triumph Speedmaster
EazyDuz
PostPosted: 16:08 - 11 Jun 2012    Post subject: Reply with quote
Smile
That is the main priority.
But apart from that, just maintenance like checking the shaft gears or making sure the brakes arent binding.
My local tyre fitter only has one of those small jack things which probably wont work with a cruiser, so i might just buy one so he can use it too when changing tyres.
yambabe
PostPosted: 16:32 - 11 Jun 2012    Post subject: Reply with quote
Shocked Why on earth would you want to do that? Confused
Both my cruisers are shaft-drive, and we've got/had other shafties over the years (my 400 eliminator, the vmax, couple of VT500s and a honda magna off the top of my head) and my fella who is a pretty competent mechanic has never felt the need to check a shaft gear on any of them!
I think you're over-thinking the whole maintenance issue for your bike to be honest.
keggyhander
PostPosted: 16:53 - 11 Jun 2012    Post subject: Reply with quote
Your mechanic needs re-training.
The shaft drive gets neglected as " zero-maintenance", so it's good practise when buying a used shaftie to change the shaft oil and re-pack the final splines with moly grease.
yambabe
PostPosted: 17:10 - 11 Jun 2012    Post subject: Reply with quote
No, you need to read what I said.
Changing the shaft oil is a 5-minute job that doesn't require the bike to be off the ground. Checking the shaft gears? When did you last check yours?
keggyhander
PostPosted: 17:13 - 11 Jun 2012    Post subject: Reply with quote
Mine's belt.
Did my dad's virago about a year ago.
r1_lad
PostPosted: 19:40 - 11 Jun 2012    Post subject: Reply with quote
Views?
I have this lift for my supermoto.
It's a solid bit of kit and works well - got mine on ebay for £70 delivered.
https://www.ebay.co.uk/itm/380347307746?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649#ht_3386wt_1301
If you need any measurements from it let me know.
RS50 -> RS125 -> GSXR600 SRAD -> 02 R1 -> Speed Triple 1050 -> Ducati Streetfighter 1099 -> DRZ400 Superetard
Quote Me Happy
PostPosted: 19:44 - 11 Jun 2012    Post subject: Reply with quote
I have the same one as r1_lad, saves any faffing about and lifts the bike up a decent height and securely.
The last post was made 14 years, 159 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.07 Sec - Server Load: 0.96 - MySQL Queries: 13 - Page Size: 117.58 Kb
