replacing a spoke without rebuilding
cb1rocket
PostPosted: 22:13 - 10 Jun 2012    Post subject: replacing a spoke without rebuilding Reply with quote
How does one go about replacing a spoke on the wheel without dismantling the other spokes or the whole wheel?
I have found that I can only feed the spoke in a straight line and turn up when I get to the elbow of the spoke - but once this far the other spokes are in the way to where the hole is in the rim......
any suggestions?
Casper
PostPosted: 22:41 - 10 Jun 2012    Post subject: Reply with quote
Is it becouse another two are crossed over at the rim end? I dont think you can without undoing a few more. You should still be able to get your wheel true undoing a couple. Just take your time and check after each time to turn the tightners.
cb1rocket
PostPosted: 23:42 - 10 Jun 2012    Post subject: Reply with quote
looks like an expensive wheel rebuild. Yes the other spokes are in the way ie they cross over but getting them out is PITA as they have rusted solid to the nipples pretty much Sad
Honda want £3 per spoke?!
Casper
PostPosted: 23:49 - 10 Jun 2012    Post subject: Reply with quote
I did it once when i burst three on a DT leaving the chain on when i took off. Embarassed Let the air out the tyre to save bursting the tube. You can always buy a few more spokes and the nipples and cut out the bad ones but obviously you need the tyre off. I managed to get mine about 2mm out what was not bad for a first time and just spinning it on the bike.
cb1rocket
PostPosted: 23:57 - 10 Jun 2012    Post subject: Reply with quote
looks like i'm going to have the whole wheel rebuilt. The other spokes are refusing to budge.
Is there anywhere where I can get a cheap set of spokes?
Saw some on ebay for about £10 a set but for a C90, who ride these things?! They are virtually non existence Laughing
Casper
PostPosted: 00:09 - 11 Jun 2012    Post subject: Reply with quote
No, i just got mine from Yamaha. This was the 80's when things were cheap. When you find a price find a price for another wheel before you start.
trisers
PostPosted: 00:14 - 11 Jun 2012    Post subject: Reply with quote
I managed to replace a spoke on my H100 by threading it through the hub right up to the elbow then flexing it enough to thread it past other spokes and into the rim...it felt like it might form a permanent bend but i guess it's hard enough steel not too.
Of course the spokes on it are pretty small diameter so maybe if it's a much larger bike you couldn't flex a spoke that far?
cb1rocket
PostPosted: 00:39 - 11 Jun 2012    Post subject: Reply with quote
it is a H100 hehe
central wheel components look like the only people to get spokes re-made.
Yes I know some of you are thinking the H100 isn't worth the price of s/s spokes.
New front and rear rims from David Silver Spares = £60
New polished s/s spokes and nipples x 2 = £65
Powder coated Hubs x 2 = £80
Labour x 2 = £104
plus P&P £30 ish
total £339 Sad
trisers
PostPosted: 08:40 - 11 Jun 2012    Post subject: Reply with quote
Yeah i got mine from central wheel components. I did manage to pick a rim up on ebay which was in good nick and rebuild one wheel with it and the new spokes.
Why on earth powder coat the hubs though...half an hour with wire brush, wire wool then autosol brought them up like new!
And as for the rebuilding, I'd never done anything like it before but gave it a go..there's one or two youtube vids to follow and although it took a little time because of the repetitive nature of it i found it was quite straightforward and not very difficult at all!
So that's reduced the cost by over a half even with new rims Wink
cb1rocket
PostPosted: 13:13 - 11 Jun 2012    Post subject: Reply with quote
Hmmm I really don't mind giving the wheel building a shot.
Did you have any problems lacing the wheel up, having to bend spokes etc?
trisers
PostPosted: 21:36 - 11 Jun 2012    Post subject: Reply with quote
No problem whatsoever doing a whole set...i found it helped having the other wheel lying alongside while i did it as a useful reference to the way the spokes are arranged...you just need a little patience to get them all in and in the correct place.
Once all the new spokes were through the rim then just screw the nipples on a few turns on each one to stop the spokes going anywhere then go around doing each one up another half turn until they start to tighten across the rim. I didn't use any special tool just a screwdriver on the back of each nipple.
Having got them all just nipped up (no real tension) i clamped the axle in a vice and put the wheel on it so i could gently spin it. Destroy a wire coat hanger and duct tape a length to the bench or vice and bend it so that the tip just touches the rim...as you spin the wheel you'll soon see any deviation caused by uneven tension in the spokes.
You'll have to work out which ones to tighten further to deviate the rim to get it to run true so when you spin it the tip of the bit of coat hanger remains just touching the rim without the rim 'wobbling' away from it (side to side or back and forwards)
It took me a while and as i said you need a little patience just because you need to keep going round tightening nipples by an eighth of a turn or so each time to get it true but once i'd done that the wheel was totally rigid and each spoke had a satisfying 'ping' to it when tapped.
First time i'd done it and totally satisfying Wink
example :- https://www.youtube.com/watch?v=-CUuugCn4eY
Casper
PostPosted: 21:53 - 11 Jun 2012    Post subject: Reply with quote
Just dont do one at a time. Put them all in the hub first and tape one side up. Screw the other in place, just screw dont do them up and start with the other. If you give one two turns you are best to go to the oposet side and give that two turns then go on to the next and do the same. Might be worth a wee bit tape on your first spoke to remember where you start. Also good chance one side spokes are longer than the other. Check before you start. Enjoy.
cb1rocket
PostPosted: 23:24 - 11 Jun 2012    Post subject: Reply with quote
thanks guys, i'll do a picture progress at some point, rims ordered, waiting to hear back from CWC about the spokes.
Going to be interesting to say the least!
trisers
PostPosted: 00:06 - 12 Jun 2012    Post subject: Reply with quote
On the H100 the spokes are the same length both sides of each wheel, but slightly different lengths front wheel to back wheel.
The angle of the heads are slightly different between the inner and outer spokes according to the manual but when i got mine from CWC i couldn't discern any difference between them at all so just fitted them...i think they flexed enough on tightening that the head nestled into the countersink on the hub quite nicely anyway without unduly stressing them.
trisers
PostPosted: 00:20 - 12 Jun 2012    Post subject: Reply with quote
And btw...the new spokes on my rear wheel transformed the appearance of the whole bike too :-
https://i2.photobucket.com/albums/y27/clivejameson/2011-07-02171932.jpg
cb1rocket
PostPosted: 09:29 - 12 Jun 2012    Post subject: Reply with quote
ooooh!
Any chance of close up pictures on the hub/spokes?
I too have notice that the head angle is different between the inner and outer spokes
map
Mr Calendar
PostPosted: 10:10 - 12 Jun 2012    Post subject: Reply with quote
Am I missing something but would a complete new (as in used) wheel not be cheaper then rebuilding a wheel with spokes?
truslack
PostPosted: 11:23 - 12 Jun 2012    Post subject: Reply with quote
A brand new pattern rear wheel for an H100 is £60.
The rear spokes are the same as the longer spokes from a C90 spoke set.
cb1rocket
PostPosted: 13:40 - 12 Jun 2012    Post subject: Reply with quote
where?
C90 spokes are shorter I have found out....?
Rear is 170 and 170.5 long spokes A and B types
truslack
PostPosted: 13:42 - 12 Jun 2012    Post subject: Reply with quote
where?
When I relaced my H100 rear wheel I used half of the spokes out of 3 packs of C90 spokes Laughing
That price was from a hi-level catalogue (I think).
cb1rocket
PostPosted: 13:53 - 12 Jun 2012    Post subject: Reply with quote
where's the pattern rear wheel you mention? I can't find one
truslack
PostPosted: 13:58 - 12 Jun 2012    Post subject: Reply with quote
...in Hi-levels catalogue.
Without a proper look, this appears to be the one https://www.hilevel1.co.uk/cpg14/displayimage.php?album=475&pos=15
No prices on their website though.
trisers
PostPosted: 17:58 - 12 Jun 2012    Post subject: Reply with quote
I searched everywhere for a replacement wheel when i did my rebuild...all those that came up second hand were a right mess and worse than i had already.
I also looked at new pattern wheels and that looks like as close as i could find but i couldn't establish if the hub width was the same so you may have to machine down the spacers if it's wider or turn up some new ones if it's narrower...and then check the sprocket alignment too.
The part number for the rear hub is 42601-102-670 and this seems to cross reference with quite a few other models but IIRC they all have 17" wheels so a complete wheel from those will be incorrect.
truslack
PostPosted: 18:25 - 12 Jun 2012    Post subject: Reply with quote
H100 SG and SJ wheels are identical to older cg125 wheels, they can also be used in SD models and get away with the separate sprocket carrier casting. I know this as I used a CG wheel in mine with the H100 brake plate and spacers.
The last post was made 14 years, 123 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.63 - MySQL Queries: 13 - Page Size: 125.71 Kb
