CG125 Smells.
DanThrax
PostPosted: 23:08 - 10 Jun 2012    Post subject: CG125 Smells. Reply with quote
Hi,
It's the newbie again, my 1998 CG125 smells of petrol pretty much all the time. Is this normal?
Can't find any leaks anywhere? And since asking for advice on tidying up the valve clearances & sparks etc, it's been running really well.
Got my bedroom window open with the bike in the back garden, and can smell it in my room. Can't be right? No leaks as I've said but could it be something else?
CG125 Newbie.
Ed Case
PostPosted: 23:10 - 10 Jun 2012    Post subject: Reply with quote
Sounds like your fuel tap isn't turning 'OFF' or the float chamber valve in the crb is duff. Most likely the tank tap needs attention.
Frost
PostPosted: 23:17 - 10 Jun 2012    Post subject: Reply with quote
You can only smell fuel once it's in the air. As fuel evaporates so quickly you can have a leak that's not even visible. Personally i'd check out the tank and tap, and replace all the fuel line.
Are you sure it's not fuel that's got on your clothes and you've taken them into your room?
DanThrax
PostPosted: 23:22 - 10 Jun 2012    Post subject: Reply with quote
It's not from any clothes, hasn't been ridden for a few days. I bought it dirt cheap, and I knew it would come with problems. I'm still really new to biking and bought it cheap to learn on as well as to learn about the bike itself.
What would I go about checking with the tank/tap and lines?
CG125 Newbie.
Ed Case
PostPosted: 23:42 - 10 Jun 2012    Post subject: Reply with quote
It might be worth running your fingers aroung the bottom edge of your tank, you could have a split or maybe a rust hole allowing fuel out, it takes very little to make a hell of a stink.
Casper
PostPosted: 23:43 - 10 Jun 2012    Post subject: Reply with quote
How is the rubber round the filler cap. If it old, hard, cracked it will let fumes out and rain water in.
DanThrax
PostPosted: 23:52 - 10 Jun 2012    Post subject: Reply with quote
Ill take all advice onboard then, but I'm cozy now. I'll check them all out in the morning and get back to you!
CG125 Newbie.
The last post was made 14 years, 127 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.15 - MySQL Queries: 13 - Page Size: 49.11 Kb
