| skikman |
 skikman Renault 5 Driver
 Posted: 20:58 - 06 Jun 2012 Post subject: |
Sounds like the carb slide is sticking. Pull the carb off and check the action as you work the throttle. ____________________ a.k.a 'Geri'
| Ariel Badger |
 Ariel Badger Super Spammer
| Casper |
 Casper World Chat Champion
| skikman |
 Posted: 21:52 - 06 Jun 2012 Post subject: |
Check that you haven't altered the cable run, and that it hasn't been pinched in the headstock lock-stops too. ____________________ a.k.a 'Geri'
| skikman |
| Usher4566 |
 Usher4566 Spanner Monkey
| skikman |
| skikman |
| skikman |
 Posted: 07:50 - 11 Jun 2012 Post subject: |
| Pete. wrote: | You're looking in all the wrong places messing with timing etc. If this is true:
| Quote: | if i blip the throttle a few times it will come down |
It points to a sticking carb slide. Maybe the slide is sticking or the cable is not returning properly.
Take the top off the carb and remove the cable. Take hold of the end of the throttle cable and push/pull on it - you should be able to snap the throttle tube open and shut with no effort just by moving the cable.
If you can't, find out why. Remove the throttle tube and clean the handlebars and the inside of the tube with WD40 or something then dry with a paper towel. Don't oil the tube or the bar, they are supposed to be fitted up clean and dry. Re-assemble it and see if the movement is free and easy.
If not, you might want to clean the last couple of inches of the throttle cable if it's a bit gummy. Again, clean with WD40 and then dry it off. The action should be very light.
If this has improved things, put it back together and see if it will now return to idle. Make sure you have some slack in the cable - it's supposed to be a little loose.
If you are still having problems returning the engine to idle, then remove the slide and inspect it for burrs. Check down the emulsion tube to make sure there is no crap down the hole and make sure there are no burrs on the needle check the action of the slid in the carb bore and see that it closes right down to nothing with the idle adjuster screwed right off. | its a cv carb.the neddle and slide are returning ok,i had it out and put wd40 around it.diaphram it ok even sealed lid down with instant gasket,float and neddle ok,no leaks in boots,cable is ok,jets are cleaned,every hole i can find is blown out,heads away with it[my head] |
| Casper |
| skikman |
| Fairies attack |
 Fairies attack Banned
| bodger |
 bodger Nova Slayer
| skikman |
| skikman |
The last post was made 14 years, 156 days ago. Instead of replying here, would creating a new thread be more useful? |
