cagiva supercity 125 7speed box selector shaft movement
befdelta7
PostPosted: 14:18 - 11 Jun 2012    Post subject: cagiva supercity 125 7speed box selector shaft movement Reply with quote
hi.. (first post in years!)
i aquired another cagiva supercity the otherday and am just giving it some tlc when yesterday i noticed the gear selector shaft has what i would say as excessive inwards and outwards movement and a slight oil leak from the seal around the shaft.
when i push the selector shaft in there are no gears there to select, when i pull it back out i can select gears.
at the moment the previous owner has used an inch and half spacer with a washer eitherside to keep the gear selector shaft in the position to select gears, i know this gear box is now knackered, but is it an easy fix to do, also could it be ok to ride like that?
was just gona get a second hand bottom end and rebuild everything to that but wont be for at least a month or so.
cheers for your replys!
Dont do a wheelie in front of a traffic copper... it gets you 3pts and £220 fine.
befdelta7
PostPosted: 07:05 - 12 Jun 2012    Post subject: Reply with quote
can anybody help??
TGB This post is not being displayed because the poster has bad karma. Unhide this post / all posts.
The last post was made 14 years, 90 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.56 - MySQL Queries: 13 - Page Size: 36.14 Kb
