| w650 |
 w650 Derestricted Danger
| map |
 map Mr Calendar
 Posted: 17:05 - 09 Jun 2012 Post subject: |
Best advice is to use a relay to connect up the grips. There are old posts on here to help if you use the search feature.
Basically can connect via relay to battery. However, relay switched via connection to live circuit. This is usually the headlight that you can tap into. So grips on when light on. You can use an extra switch if you like then can turn off when not required while riding. This can be plumbed into the fairing or sometimes come as one you can put on the bars.
As said, use search feature and all the info will be found.
With heated grips remember that although the palm of your hands may be warm the back and possibly the thumb can still be cold. You may wish to see about fitting hand guards to deflect the air flow to supplement the grips. I think for bigger bikes the ones for the V-Strom can be utililised (see threads on here and on other user/bike forums). Not sure what to use on CG. Only ever put mitten type things on that.
 ____________________ ...and the whirlwind is in the thorn trees, it's hard for thee to kick against the pricks...
Gibbs, what did Duckie look like when he was younger?  |
| EazyDuz |
 EazyDuz World Chat Champion
| stinkwheel |
| w650 |
| fatjames |
 fatjames World Chat Champion
| map |
 map Mr Calendar
| J.M. |
 J.M. World Chat Champion
| EazyDuz |
 Posted: 17:11 - 11 Jun 2012 Post subject: |
What i mean is depending on how your bike is wired, i think most have a constant live 12v running to the horn, pressing the switch just completes the circuit meaning the horn sounds.
I had heated grips wired to my horn live, and grounded at the battery neg and it worked fine. No fires, no kittens were burnt to death
Grips dont even use much power, scare mongering imo. ____________________ To shreds you say? Tss tss tss |
| J.M. |
| w650 |
The last post was made 14 years, 89 days ago. Instead of replying here, would creating a new thread be more useful? |
