speedshite 100 reliability advice
P3TR0L H34D
PostPosted: 09:28 - 13 Jun 2012    Post subject: speedshite 100 reliability advice Reply with quote
Hi all, just a quick one really, I've just bought a speedshite 100 for cheap commuting through the better weather. The only thing that was on its way out was the clunky original exhaust, so I found a cheap tecnigas exhaust locally and have proceeded to fit it. Although I read a lot of talk about lighter rollers, stiffer clutch springs and upjetting 10%. I prefferably don't want to do any of this if not totally necessary really. So my question is will not doing any of these things make it more likely to pop/seize/break or just not perform at its peak. Really its only the upjetting I'm concerned about as this means that its now running lean, which is not ideal on a tiny air cooled engine under a lot of stress. Also just to make it clear I'm not some chav trying to trick out his speedfight to "race spec" or anything like that.
Thanks in advance gents
Paul
First ever bike - 1980's Honda XL 250 (Offroad), 2004 KTM SX 125 Rattray Edition, 2004 Yamaha DT125RE, 2006 Husky WRE 125, Speedshite 100, Current- Car....... Sad
PostPosted: 11:06 - 13 Jun 2012    Post subject: Reply with quote
You need to upjet...it will need some form of fiddling anyway.
If you don't want the hassle, keep the exhaust stock.
TGB This post is not being displayed because the poster has bad karma. Unhide this post / all posts.
Nope.
PostPosted: 12:52 - 13 Jun 2012    Post subject: Reply with quote
The minimum you need to do is increase the jet size, otherwise you risk the engine running quite lean.
P3TR0L H34D
PostPosted: 13:04 - 13 Jun 2012    Post subject: Reply with quote
That is what I suspected, I don't suppose you would know what size main jet is standard on the speedfight 100? Thanks
Paul
Nope.
PostPosted: 14:25 - 13 Jun 2012    Post subject: Reply with quote
Paul
'Fraid not. Whip the carb off, turn it over, whip off the float bowl and have a look. It should be stamped on the end of the jet Thumbs Up
P3TR0L H34D
PostPosted: 17:02 - 13 Jun 2012    Post subject: Reply with quote
Just had a look and its an 86 as standard in my 2007 speedfight, they say about a 10% increase, so do you think 94 sounds sensible or 96?
Paul
cb1rocket
PostPosted: 23:14 - 13 Jun 2012    Post subject: Reply with quote
trial and error i'm afraid. time to do plug choping
SpannerMonkey
PostPosted: 01:33 - 14 Jun 2012    Post subject: Reply with quote
Hello my friend, Rollers will affect where your revs are sitting at effectively... a lot of the entry level technigas exhaust have a power-band between 7000-9500 RPM roughly. by NOT running in this RPM you will be throwing fresh fuel straight down your exhaust and not getting the power from it. for the few quid you pay for rollers, it's worth doing.
Stiffer springs just make it rev up a bit more before it takes off, increasing acceleration off the line.
Upjet is CRUCIAL. I once tried to get away with it on my old Aerox. Not a chance. not even a few hundred miles with a Leovince Handmade TT and the bike kept overheating. I thought the temp sensor was faulty so carried on riding. The bike inevitable siezed a short while after, ruining my crank and my shiny cylinder kit (That I did upjet for)
If you're just after a simple exhaust, get a Leovince touring exhaust from adrenalin pedstop if they have them in, No jetting changes or anything necessary and theyre a little cheaper
My bike? A YX140 powered one-off Monkey Bike, something a little different!
P3TR0L H34D
PostPosted: 18:48 - 15 Jun 2012    Post subject: Reply with quote
Thanks everyone for the advice, I have upjetted to match the exhaust which is working a treat. So from here I plan to now do the rollers, as the stiffer clutch springs benefits dont appeal to me. I have found two set of rollers, 9g and 6.5g the oem rollers are 12.8g. Now by "lighter" which one is that supposed to mean 6.5 or 9?
Thanks Paul
SpannerMonkey
PostPosted: 19:12 - 15 Jun 2012    Post subject: Reply with quote
Thanks Paul
Well basically the lighter you go, the higher the usual revs will be. If you go too light the bike revs its knackers off outside the powerband and you lose a lot of speed and reliability. But wont blow your bike up on first start so dont worry about experimenting.
If you go too HEAVY, the usual revs will be LOWER than the powerband, once again losing useable power. Unfortunately I dont have loads of experience with speedfight variators, but go for the 9's first.
cb1rocket
PostPosted: 19:40 - 15 Jun 2012    Post subject: Reply with quote
its working a treat.........
Have you checked the plug condition? Just because all seems ok, you should still check what colour the plug tip is in
P3TR0L H34D
PostPosted: 20:06 - 15 Jun 2012    Post subject: Reply with quote
Thanks littletomos50 for your advice I will try the 9's and see how I get on. As for the plug, it seems to be a nice coffee brown as before, but I've only riden it once so far, so I will put a new plug in and keep an eye on it, just to be 100%
Paul
The last post was made 14 years, 157 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.08 Sec - Server Load: 1.52 - MySQL Queries: 13 - Page Size: 83.82 Kb
