Throttle being weird...
DERBIXTreme
PostPosted: 15:41 - 13 Jun 2012    Post subject: Throttle being weird... Reply with quote
Hi guys,
Basically I was on my way to college today and just before I turned into the junction (bike is restricted to 30 btw if it makes a difference), going from full throttle to no throttle. Upon accelerating out of the turning, I noticed it was revving more than expected and the throttle didn't have any resistance to turn like it usually does.
Ive just ridden it home and it sounds like its revving more than normal. I pulled over and had a tinker with the throttle but this didn't make a difference. Ive also noticed if i hold the throttle barely above closed (literally turning no more than 5 degrees) the revs increase, getting to about 8000 RPM in 5 seconds from holding the throttle open very very slightly not moving!
Anyone know whats up? The throttle hasn't been like this for the last year and only changed today Sad
bike is a Derbi Senda DRD R 50
at106
PostPosted: 16:25 - 13 Jun 2012    Post subject: Reply with quote
There could be two causes, the first is that the throttle cable is too tight (not routed correctly) i would start the bike in neutral and then turn the handlebars from side to side, if the revs increase then the cable is too tight. Also make sure there is a few mm of free play in the throttle body at all steering positions.
You could also have an air leak, start the bike in neutral and spray wd40 around the carb, if the revs change then you have an air leak.
PostPosted: 16:28 - 13 Jun 2012    Post subject: Re: Throttle being weird... Reply with quote
Snapped return spring on or in your carb, get poking around.
DERBIXTreme
PostPosted: 17:25 - 13 Jun 2012    Post subject: Re: Throttle being weird... Reply with quote
Thanks! sounds like the problem! Not what you want from a '11 plate bike!!
The last post was made 14 years, 96 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 1.29 - MySQL Queries: 13 - Page Size: 45.48 Kb
