Aprillia rs 125 none runner
Your dad
PostPosted: 13:22 - 14 Jun 2012    Post subject: Aprillia rs 125 none runner Reply with quote
i have a problem with my aprilia rs125 and i don't know what's wrong with it, i have charged the batter and changed the spark plug, the bike was a runner when i bought it and now is not working.
the bike has compression and is ticking over but just wont start. When i changed the spark plug it started up fine and i then when to ride it started pulling away and it cut out and started not yo work again.i managed to get the bike working yesterday but it was going really really slow it was only doing 30 in 3rd gear full throtle but whenm i slowd down and got it back into 1st went to pull away again and then i had the same problem. When i try to start the bike it make a horrible noise and then makes a screaching noise i think it may be a fueling problem but i'm not too sure as i don't know enough about bike to start playing around with bike. If anyone has any advice i would be greatful to hear back from you, thanks. Taylor. Thumbs Up
stocksmenace
PostPosted: 14:15 - 14 Jun 2012    Post subject: Reply with quote
sound like a carb fuel/air issue( i could be wrong)...how long have you had the bike for and been riding it before this happened
Your dad
PostPosted: 14:30 - 14 Jun 2012    Post subject: Reply with quote
i have had the bike for about a week and half and the bike worked fine, i then went out for a ride for about an hour at the most, then i got to a corner dropped it into first went to pull away and it cut out.
stocksmenace
PostPosted: 14:45 - 14 Jun 2012    Post subject: Reply with quote
did you find that when you first got on the bike it seemed to accelerate really really quickly....almost too quick for what it was...the previous owner may have adjusted the air flow into the carb...what colour was the plug when you pulled it out, and have you had a look at the air filter
map
Mr Calendar
PostPosted: 14:47 - 14 Jun 2012    Post subject: Reply with quote
I am thinking sticky or bunged up carb. Ok when on idle as different jet. As soon as main jet used it isn't fuelling correctly.
stocksmenace
PostPosted: 14:52 - 14 Jun 2012    Post subject: Reply with quote
strip that bad boy and give it a clean...........
Your dad
PostPosted: 14:58 - 14 Jun 2012    Post subject: Reply with quote
Gonna strip and clean the carb tonight. I will let you know how i get on, thanks for the advice appreciate it will let you know how i get on.
stocksmenace
PostPosted: 15:01 - 14 Jun 2012    Post subject: Reply with quote
remember to take your time the bike is new to you and may have a couple of hidden problems that you have not accounted for...check the air filter more as a precautionary thing ....
map
Mr Calendar
PostPosted: 15:07 - 14 Jun 2012    Post subject: Reply with quote
Might be worth checking airbox rubbers for any splits or crack while you're at it.
dungbug
PostPosted: 15:31 - 14 Jun 2012    Post subject: Reply with quote
Check the condition of the inlet rubbers whislt you're taking the carb off as well. Thumbs Up
CBT: Pass 25/06/2011 Theory Test: Pass12/06/2012 Mod 1: Fail 08/07/2012
Mod 1 Retest: Pass 15/0702012 Mod 2: Pass 03/08/2012
Suzuki GN125 (Sold) ~ Current bike: Yamaha YZF 600R Thundercat
stocksmenace
PostPosted: 18:42 - 15 Jun 2012    Post subject: Reply with quote
how did you get on Question
The last post was made 14 years, 158 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 0.38 - MySQL Queries: 13 - Page Size: 67.28 Kb
