| GrumpyGuts |
 GrumpyGuts World Chat Champion
| CaNsA |
 CaNsA Super Spammer
| GrumpyGuts |
| kernow24 |
 kernow24 Crazy Courier
| GrumpyGuts |
| Nick 50 |
 Nick 50 World Chat Champion
| GrumpyGuts |
| andym |
 andym World Chat Champion
| GrumpyGuts |
| GrumpyGuts |
| Robby |
 Robby Dirty Old Man
 Posted: 08:47 - 15 Jun 2012 Post subject: |
Fault finding time with a multimeter.
A brief description of how the charging system works.
The alternator (may also be erroneously described as a magneto or generator) consists of a stator plate and strong magnets. The magnets spin around the stator plate, and this create AC electricity. Output is dependant on how fast the engine is turning, so it puts out between 20-60V AC. Amps aren't too important in this explanation.
The charge travels the wires (usually 3 yellow) from the alternator to the reg/rec. This RECtifies the AC output to DC, and REGulates it to 12V. A reg/rec is not 100% efficient, so it gets hot. If it gets too hot, either due to low quality components (common), poor heatsinking or airflow (common) or a corroded connector causing higher resistance (also quite common).
The 12V DC charge then goes off into the rest of the loom to power the electrical components, and charge the battery. The battery is there to provide electrical power, and also to act as a large buffer and absorb spikes - this is why you shouldn't run without a battery.
If you have ruled out the battery and reg/rec, then your problem is either with the alternator or a poor connection somewhere. Fault finding steps:
1. With the engine running at about 4000 rpm, put a multimeter set to DC volts across the battery terminals. You should be looking at around 13 volts. If you see more like 11.5 or below, the battery isn't charging. If you see more than 16 volts, you have a duff reg/rec. Important test in case new reg/rec is no good.
2. Check all of the multiplug connectors between the battery and alternator, looking for corrosion. Also check the frame earths - where the wiring loom connects to the frame with an eyelet terminal. Any corrosion here will be a problem.
3. If you find any corrosion, clean it up and repeat step 1.
4. No corrosion, no power, time to look at the alternator. It is made up of three parts, hence the 3 wires coming off it. In theory, two parts of it could fail and it would still create some current. With everything connected up, set your alternator to AC volts. Put the positive terminal in the back of the connector with the alternator output (yellow) wires, and the negative onto the frame of the bike. Do this for each individual wire. If you get a reading of 0, your alternator isn't making any charge. If you get a reading of 10+ volts from any of the wires, that part of the alternator is working. Do this test with the engine running.
5. Reading 0 on all or some parts, you have a stator plate problem. The stator plate is made of copper coils covered in epoxy resin. Over time this epoxy will go brittle and flake off (30+ years usually), and then the copper wiring will become contaminated, heat up too much, and fail. Alternatively, the wiring could be of low quality of have a manafacturing or design flaw which allows it to get too hot and fail. The solution is replacement.
6. In some rare cases the magnets detach themselves from the flywheel and destroy the alternator, along with making lots of noise. This should only be a concern if you have a GPZ500. |
| GrumpyGuts |
 Posted: 17:37 - 16 Jun 2012 Post subject: |
This is my problem
https://i45.tinypic.com/2vtxymp.jpg ____________________ My Bikes: Lifan Beat 125cc '11 -> Suzuki B120P '76 -> Suzuki EN 125-2A '08 -> Honda CG 125 '04 -> Honda CB600F Hornet '98 -> Kawasaki ZZR 600 '99 -> Kawasaki GPZ 500S '95 (Current)
Theory test passed - 09/02/2012 >>>> Module 1 passed 24/07/2012 >>>> Module 2 passed 24/10/2012 |
| mysterious_rider |
 mysterious_rider World Chat Champion
| GrumpyGuts |
| Nick 50 |
| mysterious_rider |
 Posted: 22:05 - 16 Jun 2012 Post subject: |
| GrumpyGuts |
The last post was made 14 years, 107 days ago. Instead of replying here, would creating a new thread be more useful? |
