Dynojet Kits
garth
PostPosted: 08:33 - 15 Jun 2012    Post subject: Dynojet Kits Reply with quote
1998 600 Hornet.
I have the above, with the 5.5 - 7k rpm buzziness, apparantly caused by a flat spot and cured by a dynojet kit.
Is it as easy to fit as just changing main jets and needles or is set up time needed?
thomp1983
PostPosted: 12:23 - 15 Jun 2012    Post subject: Reply with quote
you'd need to look at what's causing your flat spot. also you will need to find out from dynojet what the kit is designed for, i know with my zxr the stage 1 kit is designed for a bike that has an aftermarket can and free flow air filter, the bike came with the jets fitted and i didn't know about the air filter until i started investigating why it was always rich at lower revs which was because it didn't have the air filter the jets were designed to work with
chris
The last post was made 14 years, 158 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.03 Sec - Server Load: 0.23 - MySQL Queries: 13 - Page Size: 31.15 Kb
