GSF400V Starting issues
Lynxx
PostPosted: 14:26 - 15 Jun 2012    Post subject: GSF400V Starting issues Reply with quote
Hi all, i have recently had a problem starting my 400 bandit, it stemmed from getting some crappy watered down fuel from Morrison's
and i got so angry with it running like crap from the fuel i just left it sit for a week or 2.. then when i drained it and cleaned the carbs. It wouldnt start unless you put your hands over the back of the carbs, sprayed starter fluid into it or poured some fuel onto the air filter, once its running it will Idle a little. Everything worked well until i had this crap fuel in it and the fuel in it now is from Texaco so it cant be too bad ?
Ive checked almost everything all the spark plugs are clean and in working condition, the air filter is a bit dirty but removing it does not help. all 4 clamps are on the air box, the mixture screws are all set too 2 turns, and there is no holes in the rubber CV slides. It runs great and revs crisply after 3,000 rpm. But anything below that is pitiful. Any ideas what it is ? do i need to soak my carbs in cleaner, all i did for a clean was remove the jets and blow the lines out with an air compressor. it is clean and i dont think the jets are blocked, i could be wrong though.
Current: 1992 Suzuki GSF400V - 1984 Honda MTX200 (SOLD) - 1975 Honda Xl350 (SOLD) - 1993 Honda CB250 (SOLD)
Lynxx
PostPosted: 14:29 - 15 Jun 2012    Post subject: Reply with quote
I checked the rubber intake boots too, one was leaking a bit where the last owner had jerry rigged it and put a brass line into the boot to run the vacuum on the carb. That is now removed and fixed. Oh and the fuel petcock is gravity fed, it is no longer vacuum fed.
Lynxx
PostPosted: 19:26 - 15 Jun 2012    Post subject: Reply with quote
completely tore them down today, every jet come out.. replaced the main jets with brand new #110's runs a bit better. havn't really experimented on it yet though.
The last post was made 14 years, 157 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.07 Sec - Server Load: 0.43 - MySQL Queries: 13 - Page Size: 40.49 Kb
