Clutch bite point too high
Pukka
PostPosted: 19:49 - 15 Jun 2012    Post subject: Clutch bite point too high Reply with quote
My clutch cable snapped the other day so ive had to replace it. (bike is a Honda CB500S)
However, before the cable snapped my clutches bite point would start around 40-50% of the lever travel from the handlebar. Now however the bite point is higher to around 70%-80% of the travel which is making it quite annoying to ride.
The cables got atm around 20mm freeplay (its max limit). Am i right in thinking that increasing the freeplay should move the biting point closer towards the bars?, because the lever feels very loose as it is at the moment and dont really want it any looser.
I've tried adjusting it with both the lever adjuster and the engine side adjuster and it doesnt seem to make much difference as the bite point is always too far away. The cable is routed the same way as the cable that i replaced.
Clutch itself was working fine before it snapped and upon letting the clutch out in 4th makes the bike stall so i think the clutch is still working as it should.
Thanks for any help
Nick 50
PostPosted: 21:27 - 15 Jun 2012    Post subject: Reply with quote
Just in case it helps:
https://www.scribd.com/doc/7180016/Honda-CB500S-9301-Service-Manual
Page 62.
Silly question, but is the length of new cable the same as the old one?
Sounds like the cable is a tad too long.
Pukka
PostPosted: 21:41 - 15 Jun 2012    Post subject: Reply with quote
Page 62.
Already got the manual downloaded but thanks!
Im not too sure about the length of the actual cable (as i threw it away when the actual cable snapped) but the rubber sleeve is the same length. However the sleeves are angled slightly at the top of the cable, with the older cable being much more so
I looked on https://www.hondaoriginalparts.com/ (and wemoto as well!) and it stats that the CB500S cable cable part number is 22870-MY5-G30 so i bought this (a genuine one at that). However the clutch cable for the standard (non-faired) CB500's it stats the part number is 22870-MY5-730.
So i apprently have the correct cable but it is starting to look like its too long...
dragstaar
PostPosted: 22:02 - 15 Jun 2012    Post subject: Reply with quote
where are you adjusting the freeplay? try adjusting at the clutch end rather than the handlebar end.
Pukka
PostPosted: 22:08 - 15 Jun 2012    Post subject: Reply with quote
Ive tryed it with the handbar adjuster fully wound in and then adjusting from the clutch end to the freeplay specified but doesnt seem to make any difference
dragstaar
PostPosted: 22:13 - 15 Jun 2012    Post subject: Reply with quote
Thinking So there's no change at all when you are adjusting at the clutch end? The handlebar end is really for the small tweaks. You should see some change at least when adjusting at the clutch end. Seems odd that you're not
Pukka
PostPosted: 22:31 - 15 Jun 2012    Post subject: Reply with quote
Yeah the bite point is always around the later stages of the lever unless theres literally loads of freeplay (more than 30mmish and even then its still not close enough) which is then really uncofortable to ride with.
I think im going to take the tank/fairings off tomorrow to ensure its not catching on anything and the routing was actully correct in the first place and then try adjusting it again
Pukka
PostPosted: 07:11 - 17 Jun 2012    Post subject: Reply with quote
Well i took the tank of to get a better look and it definitly is being routed correctly as compared to someone elses.
I was also suggested to simulate lengthening the outer cable to see if it was too long by placing something between the lever adjuster and the outer cable to see if the cable was too long. However all that it did was mean less adjustment needed to be done but still resulted in the clutch releasing higher up the lever (again unless there was loads of freeplay).
I measured the point at which its starting to bite with this new cable which is around 5-6cm of travel from the bars with 8cm being the total travel of the lever. The point at which the clutch used to bite was around the 3cm area (and this is also the point on someone elses bike)
any suggestions? Confused
1cyl
PostPosted: 10:09 - 17 Jun 2012    Post subject: Reply with quote
If the cable was too long, wouldn't the issue be "clutch not clearing properly?"
How about making the lever really slack when the clutch is engaged, to bring bite point closer to bar?
Personally: If there is a fraction of play in the lever when the clutch is engaged, with no slipping. And no snagging when breaking hard and going down through the gears while its pulled.........Id be satisfied it was adjusted correctly, regardless of bite point.
Chase my Witch up, Catch my Snitch up.
The SMC | The Pit | Stable
Pukka
PostPosted: 10:32 - 17 Jun 2012    Post subject: Reply with quote
To bring the point at which is comfotable to me literally half of the clutches travel is freeplay and it starts to drag quite badly. With enough of freeplay to stop drag, it doesnt slip but because the point is so far out that i cant set off cleanly and im getting hand pain after just a few miles of stop/start traffic
Ive decided to buy a standard cb500 clutch cable just to see if it makes any difference... if not i guess im going to have to deal with it and adjust.
The last post was made 14 years, 155 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.05 Sec - Server Load: 0.24 - MySQL Queries: 13 - Page Size: 67.03 Kb
