Oil stop leak products.
R1stu
Shrek!
PostPosted: 13:11 - 17 Jun 2012    Post subject: Oil stop leak products. Reply with quote
Are they ok to use in bikes?
The Honda is burning oil now and I was tempted to get some of the wynns stop leak stuff to try and help rejuvinate the seals.
Good Or bad idea?
Carbon closet tart! https://www.bikepics.com/members/r6stuk/02r6/
Stolen bike. 2000 R1: https://www.bikepics.com/members/r6stuk/00r1/
Current bike 1991 Honda ST1100 Pan European, 1986 Honda cb350sg (Finished)
Casper
PostPosted: 13:48 - 17 Jun 2012    Post subject: Reply with quote
I vote for bad idea. If they are designed to stop oil leak then what oil line inside the engine does it block.
I cant remember the name but there was a product that you stuck down the plug holes and run the motor and it sealed the grooves on worn cylinders. I have use it on an old car but never a bike.
Rob W
PostPosted: 16:17 - 17 Jun 2012    Post subject: Reply with quote
I'd say bad as well.
I've used it before on the Mrs car and it did nothing.
acid drop
PostPosted: 18:11 - 17 Jun 2012    Post subject: Reply with quote
That was piston seal made by holts, in my experience none of the so called stop leak remedys ever worked for me
temeluchus
PostPosted: 18:12 - 17 Jun 2012    Post subject: Reply with quote
Castrol GTX high mileage does the trick and is ok for wet clutches.
The last post was made 14 years, 154 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.06 Sec - Server Load: 0.34 - MySQL Queries: 13 - Page Size: 43.91 Kb
