Tubeless tyre fix
Ollyswing
PostPosted: 21:08 - 16 Jun 2012    Post subject: Tubeless tyre fix Reply with quote
Hi all! Sorry if I don't get some rules right straight away, I'm a newby. I'm looking for advice as it suggests in the heading. I have a honda s-wing with tubeless tires of which the rear one have a nail (or nail like object) stuck in it. The tyre apart from this is a healthy michellin one with good thread with couple thousand miles in it. After researching online i found a product which can plug this hole but for that i have to take the nail out first. After playing about for a while trying to get it out I lost sight of the object. It kind of plugged the tyre because it keeps the air in unless i fiddle around the hole in which case I can hear it coming out again (the air).. Could someone please advice regarding this issue? Can i carry out the "plugging in" while the nail is inside? I'd really apprechiate some help! Thank you very much!
stocksmenace
PostPosted: 22:35 - 16 Jun 2012    Post subject: Reply with quote
personally i say get it out ....
Triumph Sprint 900..Prev-ZZR600-Derbi terra-Mz251-Hyo Aquila
map
Mr Calendar
PostPosted: 23:53 - 16 Jun 2012    Post subject: Reply with quote
Two options.
1.
Get one of the BMW style puncture repair kit where you put/screw a plug in the outside of the tyre to fit the leak. You first make the hole bigger first - see instructions. Do it correctly this time
or, if you've messed up the repair then
2.
Replace the tyre.
IIRC the new Honda S-Wing* - assuming this is what you have is a scooter. So no big money for rubber. If you can remove the wheel yourself and take to tyre shop it's not that expensive to get fitted to loose wheel.
HTH Thumbs Up
* hopefully not confusing this to the Silverwing which is a scooter or going back in time was actually the name Honda put on a motorcycle.
reckless_b
PostPosted: 15:28 - 17 Jun 2012    Post subject: Reply with quote
take it in for a repair , national tyres do a great service on loose wheels, or buy a "stop and go" diy plugging kit, m and p stock them, although these are only supposed to be a get you home fix, the plug can be fitted with the wheel still in place
40 years on the road on and sometimes off bikes with a very recent OFF
kestrel
PostPosted: 15:53 - 17 Jun 2012    Post subject: Reply with quote
^^^This
Take the wheel to your local tyre fitter and let him repair it. If the nail is in the treaded area it can be repaired, if it's in the side wall the tyre is fucked. National Tyres in my area charge £10 for a puncture repair on a loose wheel, or a fiver for the tea money if they aren't too busy.
Isle of Man.........Road Racing Capital Of The World
Ollyswing
PostPosted: 22:46 - 17 Jun 2012    Post subject: Reply with quote
Thank you for quick reply. I ended up riding it to a workshop that's open on Sunday and had it replaced. It was 64 quid but at least it's done.
The last post was made 14 years, 154 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.04 Sec - Server Load: 0.98 - MySQL Queries: 13 - Page Size: 48.41 Kb
