CB125T wont start after carb cleaning
joelonghair
PostPosted: 22:14 - 17 Jun 2012    Post subject: CB125T wont start after carb cleaning Reply with quote
Ok so back in March I made a post as after cleaning and refitting my carbs they were pissing petrol everywhere! Thanks to the help of the members here I realised the float height was incorrectly set.
Today I finally got round to sorting them out! Fuel flows into the bowls as normal and there is no petrol leakage thank god!
However, the engine will not start. Turns over perfectly but so sign of life. The battery seems to be ok as the front headlight turns on perfectly.
Does anyone have any suggestions as to why this might be? Before the carb removal a few months ago the bike started first or second kick.
Oh, if it makes any difference the rear light is not connected at the moment.
Much obliged,
Joe
joelonghair
PostPosted: 00:01 - 18 Jun 2012    Post subject: Reply with quote
Wouldn't know how to check! This is all new to me, but am fairly competent(ish) when given a haynes or with some direction. How do i check for this?
Cheers
Casper
PostPosted: 00:17 - 18 Jun 2012    Post subject: Reply with quote
Cheers
Take a plug out and stick it in the cap, lay on flat part of engine and press the starter and look for spark. Do both sides. If you have a spare plug use that, saves taking your out but you could have a duff plug (doubtfull)
reckless_b
PostPosted: 09:33 - 18 Jun 2012    Post subject: Reply with quote
when the plugs are in and everything is connected as it should be you could try a quick squirt of easy start following the directions on the can, if it fires then you would be looking at carb problems
40 years on the road on and sometimes off bikes with a very recent OFF
The last post was made 14 years, 154 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.04 Sec - Server Load: 0.41 - MySQL Queries: 13 - Page Size: 43.92 Kb
