Feeling Gears Bite When Fully Clutched In
Zombeh
PostPosted: 11:38 - 19 Jun 2012    Post subject: Feeling Gears Bite When Fully Clutched In Reply with quote
I ride a CB500 and recently I have been feeling the gears grind together when shifting. This is especially noticeable when moving around 1st and 2nd gears, and is probably less so because I'm changing quite tenderly between higher gears so the gears change more easily.
Can anyone identify a part of the clutch that is obviously worn out that I might be able to change myself, or how I can go about taking it apart and fault finding?
Unfortunately I don't have any proper garage space at the moment. Am I better off asking a mechanic to sort the clutch out and avoid any total disasters? I am quite keen to learn more and more about servicing the bike myself.
Nexus Icon
PostPosted: 13:25 - 19 Jun 2012    Post subject: Reply with quote
Adjust the cable?
Greetings from Shitsville!
dungbug
PostPosted: 13:50 - 19 Jun 2012    Post subject: Reply with quote
Nexus Icon wrote:
Adjust the cable?
+1, start with the basics, do you have a workshop manual for the bike?
CBT: Pass 25/06/2011 Theory Test: Pass12/06/2012 Mod 1: Fail 08/07/2012
Mod 1 Retest: Pass 15/0702012 Mod 2: Pass 03/08/2012
Suzuki GN125 (Sold) ~ Current bike: Yamaha YZF 600R Thundercat
Zombeh
PostPosted: 14:13 - 19 Jun 2012    Post subject: Reply with quote
I've already done that it's definitely not the cable.
What I really need is to be confident that it's a clutch problem before I take everything apart and have a look. I believe that it could also be in the gears or gear change lever.
blade023
PostPosted: 23:01 - 19 Jun 2012    Post subject: Reply with quote
I have the Haynes manual for the '93 to '01 CB500 twin if you want? It's in pdf format, and I'm just uploading it to a server now. I'll post a link up here once it's up...
Here you go
Current: VFR800 2008 13.7k and rising rapidly!
Sorn: 2003 FZS1000 30k(ish) looking to sell.
Zombeh
PostPosted: 08:58 - 20 Jun 2012    Post subject: Reply with quote
Thank you sir, this will be very useful.
blade023
PostPosted: 23:19 - 21 Jun 2012    Post subject: Reply with quote
Welcome. I've already found it quite useful for various different things.
The last post was made 13 years, 327 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 1.08 - MySQL Queries: 13 - Page Size: 51.34 Kb
