| StormCrow |
 StormCrow Scooby Slapper
 Posted: 00:57 - 19 Jun 2012 Post subject: GPZ500 - building spare engine... (long!) |
TL:DR:- What do I need to look out for when building GPZ500 engine?
Hi folks
While my bike seems to be running reasonably well, she's on 63,000 miles.
I have gained various parts to rebuild a spare engine - in order to swap out.
I have a good bottom end - bearings look fine, gears all look perfect, no scoring etc anywhere.
I have just bought an apparently good top end - pistons, barrels and head.
Most parts are from a Gen 1 engine - I will be swapping my Gen 2 CCT over (will put together with Gen 1 for setting timing etc) and will be swapping flywheels and stator (spare engine doesn't have them).
I have ordered a cam chain with 8,300 miles on it - which will be swapped.
Obviously I intend to pull the valves and lap in etc - alongside lapping the head as per FOG.
Now then - the gears...
I know that the Gen 2 gearset is preferable to the Gen 1 - usually because of slipping into a false neutral - yes? At present I only have a decent looking Gen 1 set - anything specific I should inspect? My current gearbox is whining in 4th so that's out. (Also Gen 1)
I intend to measure and hopefully reuse the piston rings - the whole thing is on a budget and they ain't cheap...
The primary drive chain from my bottom end set looks fine - I will remeasure the link lengths but if I remember correctly it was within spec.
So - consider this a sort of project thread - I can take some pictures throughout if the people so require it!
My first question (of likely many!) - is there anything else I should be specifically checking or looking for? Anything I've missed? Parts will be checked as they are installed - certainly the bottom end visually looks fine - no chipped teeth anywhere, bearing shells look fine, crank seems good etc. The top will be inspected after I pick it up - I know that camshafts etc aren't swappable due to machined surfaces etc - presumably lifters, valves etc are though?
What is the suggested course of action with valve stem seals / other gaskets? I know it's possible to rebuild and use existing gaskets, but, for example, would it be an idea to do the valve stem seals at least? A full gasket set is around £80 - or £60 if I order from the States
Cheers |
| lihp |
 lihp World Chat Champion
| sickpup |
 sickpup Old Timer
 Posted: 04:15 - 19 Jun 2012 Post subject: |
| Rogerborg |
 Rogerborg nimbA
 Posted: 09:20 - 19 Jun 2012 Post subject: |
I have to ask... why are you spending time and money on preparing to swap out a working engine?
It's not broke, don't fix it. If it does break, fix the broken bits.
Is this purely for the lulz? ____________________ Biking is 1/20th as dangerous as horse riding.
 Posted: 10:42 - 19 Jun 2012 Post subject: |
Leave the gearbox alone. If you're in there, check the hooks on the primary gearshift mechanism (that catch and pull the selector drum round) aren't rounded off.
I confidently predict you are going to spend more on this than a good, working second hand engine would cost.
Remember the IC igniter goes with the ignition system. No point fitting a second generation stator to a first generation bike without the right black box. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| lihp |
| devojunior |
 devojunior Brolly Dolly
| jjdugen |
 jjdugen World Chat Champion
| StormCrow |
| lihp |
| StormCrow |
| StormCrow |
 Posted: 20:29 - 19 Jun 2012 Post subject: |
| devojunior wrote: | your 63,000 mile cam chain could well be in far bette rthan a 8,000 mile chain how do you know that the engine wasnt run low on oil at some point it mmay have been ragged within a inch of its life.
seem slike alot of waste of time tbh what have you gained from all this. |
You're correct. (Even if it does look like you asked your cat to type it, your time is obviously too precious to use punctuation!)
I don't know. And until it arrives, and I can measure and inspect it, I won't know. But I DO know that for £10 - it's a lot cheaper than the £50 for the new one. And that £50 could be better spent elsewhere. But equally - how do I know that MY chain on my 63,000 mile bike is any better? That it's never been thrashed? (I know that to be untrue for sure! ). Balance of probabilities, I know which I'd side with...
So you've never done something just to say 'I've done that', or for the satisfaction of KNOWING that your engine (or brakes, suspension etc) is good? Glad you can afford to take it to the shop when it all goes wrong. I can't - I'd rather learn a new skill myself.
What I will have gained (when it's done) is the confidence to push the engine and not worry that it'll break down, depositing me in a hedge or stranded miles from anywhere.
And maybe more importantly (to me at least) - the satisfaction of knowing every inch of the vehicle to which I am basically trusting my life.
That's what I'll have gained.
Stinkwheel - You're almost certainly correct. But as I say - at least I'll know that the money will be well spent - who knows what's happened to any of the bikes on eBay or whatever whose engines are for sale!
jjdugen - Good information there - thanks  |
| Robby |
 Robby Dirty Old Man
| tsmith |
 tsmith Traffic Copper
The last post was made 13 years, 208 days ago. Instead of replying here, would creating a new thread be more useful? |
