Suspension Setup?
johnsmith222
PostPosted: 16:28 - 19 Jun 2012    Post subject: Suspension Setup? Reply with quote
Hi guys.
I have a ZX9R E1 and it has an ohlins rear shock and ohlins springs.
The problem I've been having is that the suspension is too "stiff". It feels as if the front end has two solid forks rather than any "springyness".
The suspension was set up for the previous owner who weighed around 15.5 stone. I'm a stone lighter. Also, I suspect it was set up for "sports" riding rather than real road riding. It's great as it doesn't bounce about at 100mph+ on smooth private roads. But on bumpy country roads its not good.
I'd actually say I'm faster on my ZZR600 with 10 year old bouncy suspension and pilot road 1 tyres than I am on the ZX9R.
I'm just used to feeling the bumps being absorbed etc.
I don't know a lot about adjusting suspension so I am looking for tips as to what I should start off with reducing.
There are suspension settings for the previous owner at the back of my manual. I can post these to work from.
mitch1
PostPosted: 16:37 - 19 Jun 2012    Post subject: Reply with quote
some good info here and some base settings to try https://www.sportrider.com/motorcycle_suspension/index.html
johnsmith222
PostPosted: 17:17 - 19 Jun 2012    Post subject: Reply with quote
Thanks Mitch. I'll have a look into that website as there seems to be loads of info there.
I also managed to come across this video in which Keith Code explains how to adjust suspension using the same bike I have.
Still, I will need to do a bit of reading and experimenting.
https://www.youtube.com/watch?v=bBlqVx4mWUw
The only problem with the video is that the rider in the video knows how he likes the suspension. eg. "Cody, how do you like the rear?" "35mm".
I'll need to do some reading.
Fizzer Thou
PostPosted: 17:37 - 19 Jun 2012    Post subject: Reply with quote
The main item to adjust is the SAG,which is the amount that the bike squats with the rider on board.Once this is adjusted properly then move on to the rebound adjustment.This damping adjuster has some effect on the compression damping circuit.keep a note of which way you go on the damper 'clickers' after going +/- 3 clicks at a time so that you can feel a real differance,especially with Ohlins gear.
If the front end is too solid it may be that the fork oil is too heavy a grade.My R1 demands 5w,which is quite light.Together with Ohlins fork springs both ends can be balanced.Once I had installed the Ohlins shock and dialed that in I found that the front was severely wanting attention.Once sorted,although a bit hard for some,once I start to push the pace it gels and works as it should.
If you were anywhere near bexleyheath I would say pop by Wink
Always have a 'Plan B'
johnsmith222
PostPosted: 17:55 - 19 Jun 2012    Post subject: Reply with quote
Thanks Fizzer for the offer to jump by but unfortunately I am in Glasgow or I would have taken you up on the offer. Thumbs Up
I'm getting an idea of how I should go about it, or at least what my goal should be. I think I need to increase the sag and I've watched videos showing the measurements needed etc. I'll measure sag at the settings and then adjust to see if the increase helps. I find the bike handles better with a pillion than it does with just me on it, so it is obviously set-up for a heavier rider.
I will go over everything and take note of the current set-up just in case I make a mess of things. As you said, once I have setup the sag, I will try adjusting the rebound 3 clicks at a time to figure out what I really want from the setup.
Thanks again Fizzer. I may not know suspension, but I feel I know where I should start now.
Barnaby This post is not being displayed because the poster is banned. Unhide this post / all posts.
The last post was made 13 years, 199 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.21 - MySQL Queries: 13 - Page Size: 50.51 Kb
