Brake judder when coming to a stop
Snorty
PostPosted: 11:59 - 20 Jun 2012    Post subject: Brake judder when coming to a stop Reply with quote
For some reason I'm getting some strange feedback like a vibration through the bars/lever just as I come to a stop. What could be causing this it's only just started?
PostPosted: 12:04 - 20 Jun 2012    Post subject: Re: Brake judder when coming to a stop Reply with quote
Check wheel bearings - often a sign they're getting a bit loose. At speed you often don't notice so much as they're spinning fast enough.
FantasticMrFo...
PostPosted: 13:20 - 20 Jun 2012    Post subject: Reply with quote
I'd have a check on the run out of your disk as well, its likely that the disk is a little warped, causing increased friction in some areas and decreased friction in others, causing a very fast stop start type motion.
slyrob
PostPosted: 13:26 - 20 Jun 2012    Post subject: Reply with quote
I had the same on the zx6r, cleaned the calipers out and it went away
Pitslayer wrote "it could be Ndubz.....ruining this once great place with donkey gobbling loafer knobbing "music".
silky666 wrote "In my eyes, when you shake cocks with the devil, you may as well go for the full reach around"
Villers wrote "as reliable as a ginger stepchild on smack"
shereen
PostPosted: 13:35 - 20 Jun 2012    Post subject: Reply with quote
I had exactly the same problem on the NC30 - whilst braking just before stopping it would judder. After much investigation it turned out to be the head stock bearings.
The last post was made 13 years, 197 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 1.04 - MySQL Queries: 13 - Page Size: 47.3 Kb
