| parv1 |
 parv1 Nova Slayer
 Posted: 20:41 - 20 Jun 2012 Post subject: Total and Utter Idiot!!!! |
I'm not very mechancally minded and you will be able to tell that due to my silky soft hands.
But I decided to check my engine oil on my Honda Lead 110. I checked it and kind of decided there only seems to be a small thimblefull in there so let me top it up.
So after wiping off the dip stick, i kept pouring and pouring. I couldn't see a min or max indicator so just poured it until it was halfway up the dipstick. This was last nite.
I was proud and told my friend how good a mechanic i was.
Anyway, this morning, I start it up and its ticking along nicely and i notice that its not picking up as well as it used to but i think that its just what happens when you put more oil in.
Same thing happens on the way home. So i get home and decide to check the owners manual and read that its just the first inch that i need to top up to.
So i get home and start to try undo the bolt that i think is to drain the oil........ no wrong bolt........try a different one........no wrong bolt again........ ah finally found it. Unscrewed it and the oil pours out with some pressure all over the floor missing the oil pan (cut out milk carton) and all over the floor
Scramble to get the oil in to the milk carton and finally start wiping the floor as it drains.
I wiggle the bike and get it all out. Put the bolt back in and fill it up again but this time just to the top of the proper mark!!
Woohoo my first oil change  ____________________ CBT passed Jan 2011/ Mod 1 passed July 2012/ Mod 2 passed July 2012
Theory Test Passed; Questions 45/50, Hazard Perception 70/75
Peugeot Speedfight 50cc > Piaggio Zip 50cc > Honda Lead 110cc + Ybr 125 |
| numpty2 |
 numpty2 Trackday Trickster
| Turkish |
 Turkish Crazy Courier
| numpty2 |
| parv1 |
 parv1 Nova Slayer
| Robby |
 Robby Dirty Old Man
| numpty2 |
| parv1 |
 parv1 Nova Slayer
 Posted: 22:05 - 20 Jun 2012 Post subject: |
Just be aware that what usually happens if an engine has been overfilled is it starts to shove the excess oil out of the crankcase breather (assuming it didn't fluid-lock, which it hasn't because it's still running).
The crankcase breather is usually routed into the airbox.
SO
You might have an airbox and air filter contaminated with engine oil. If the filter is choked with oil, your bike will not be able to suck in enough air, will run rich and be very down on power. The happily simple solution is to wipe it all out with a clean rag then clean or replace the filter as appropriate.
TL;DR It might have fired some oil into the airbox. If it's running rough, have a look in there. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| parv1 |
 parv1 Nova Slayer
| pendulum |
 pendulum Traffic Copper
 Posted: 22:24 - 20 Jun 2012 Post subject: |
Oil changes are often the first maintenance job a noob ever does... that's why so many oil changes go wrong. I can already see from this thread that I'm not the only one to have poured (expensive ) oil into a car engine, with the sump plug still out... all over the drive...  ____________________ 1998 CG125 (Sold) CB500 [+ Clio 172]
Usually_Wrong: I tend to fail more than pass. [Speaking about Theory Practice]
Usually_Wrong: im on unemployment at the moment |
| LongJohn22 |
 LongJohn22 Trackday Trickster
| DrDonnyBrago |
 Posted: 23:50 - 20 Jun 2012 Post subject: |
I once left the old o-ring of my oil filter stuck to the engine and screwed the new filter on top of it (in my defence, it's almost impossable to see without removing the fairing, I was working by touch).
Fired the engine up, no problem and left it ticking over. First time I blipped the throttle it spewed ALL the oil out past the o-ring and into the belly pan at high pressure in five seconds flat. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| parv1 |
 parv1 Nova Slayer
 Posted: 14:25 - 21 Jun 2012 Post subject: |
Well i rode in to work this morning and it seems to accelerate ok. Will try again this evening to give it a good run.
Thanks for the advice guys.
On to the next bit of tinkering  ____________________ CBT passed Jan 2011/ Mod 1 passed July 2012/ Mod 2 passed July 2012
The last post was made 13 years, 299 days ago. Instead of replying here, would creating a new thread be more useful? |
