Minimum inside leg for a Varadero 125?
eebygum
PostPosted: 14:43 - 21 Jun 2012    Post subject: Minimum inside leg for a Varadero 125? Reply with quote
Does anybody have any experience of what is the minimum inside leg for a Varadero 125?
I know its not just about seat height but width too.
Break it to me gently.
At 30inches inside leg am I confined to a YBR Sad
guile
PostPosted: 15:02 - 21 Jun 2012    Post subject: Reply with quote
I have similar leg size problems. I would love a supermoto but I don't think I will ever fit on one properly for stop/start urban traffic.
map
Mr Calendar
PostPosted: 15:12 - 21 Jun 2012    Post subject: Re: Minimum inside leg for a Varadero 125? Reply with quote
eebygum wrote:
Does anybody have any experience of what is the minimum inside leg for a Varadero 125? ...
The reference to the cycle-ergo site has been posted before in other threads (I did at least one).
It might be worth having a play on that. You can select foot down in options to see if you're on tip-toes (although you will tend to lean a bike when stopped anyhow).
Link click here and then chose your bike. The Varadero is there under Honda. A 30" inside leg would appear no problem, seat height at 32.2".
HTH Thumbs Up
blito
PostPosted: 17:50 - 21 Jun 2012    Post subject: Reply with quote
The seat on my Zontes Monster is about the same height as the Vara although a little narrower. My inside leg is 31" and I can get both feet flat on the floor. I suspect I would be able to on the Vara too as the apparent size of the 'dero is as much to do with the high bars and upper fairing as it is the seat height.
Only thing is to go sit on one to see Smile
2012 Zontes Monster
sidewinder
PostPosted: 17:53 - 21 Jun 2012    Post subject: Reply with quote
You can get a lowering kit for the varadero Thumbs Up getting the seat narrowed will help as well.. Thumbs Up
snikks
PostPosted: 18:14 - 21 Jun 2012    Post subject: Re: Minimum inside leg for a Varadero 125? Reply with quote
I suspect you'll be fine - it's not as big as it at first appears to be, as has been said, the apparent size is more to do with the fairing than anything else.
- CBT: 02/01/11 Theory: 26/04/11 Mod 1: 19/05/11 Mod 2: 19/08/11
- 2007 Honda XL125V Varadero (Sold), 1999 Yamaha FZS600 Fazer (Sold), 2001 CBR600F
eebygum
PostPosted: 18:41 - 21 Jun 2012    Post subject: Reply with quote
Yippee!
Thanks guys. Smile
Richtea
PostPosted: 19:03 - 21 Jun 2012    Post subject: Reply with quote
From my experience I dont think you'd have any problems with a Varadero.
I'm a 33' inside leg but the set up of the Varadero is pretty forgiving of most shapes and sizes.
2005 Honda Varadero 125xl > 2005 GS500F > 2007 DRZ400 SM > 600 Bandit & Yamaha YP250
Alex_B
PostPosted: 21:38 - 21 Jun 2012    Post subject: Reply with quote
My inside leg is likely a tiny bit shorter Very Happy
Hey, I got long body and am 5' 10" but I loved that 125.
The best 125cc EVER and I don't care for ya YBR's and so on Wink
It will fit you and you will love it Thumbs Up
My Lane Position is always AWESOME!!
bigguy
PostPosted: 18:26 - 23 Jun 2012    Post subject: Reply with quote
I Have a varadero at the moment and i am a 31 inside leg, both feet can touch the ground easy when im stopped, there has been no modifications to my bike which makes it lower (unless 15st in weight counts lol) so i think a 30 inside leg should work no probs..good luck with it if you get one as they are great bikes,
BruceT
PostPosted: 18:59 - 23 Jun 2012    Post subject: Reply with quote
Not forgetting that when stopped you tend to lean the bike to your left anyway, sit half off the seat to give yourself some more leg length/more foot on the ground
VT125
kelvyn
PostPosted: 19:01 - 23 Jun 2012    Post subject: Reply with quote
29/30" Inside leg and I ride a bike with a 38.3" seat height.
Don't worry about seat height too much.
Teflon-Mike This post is not being displayed because it has a low rating (Abusive). Unhide this post / all posts.
Anthrax1039
PostPosted: 01:42 - 24 Jun 2012    Post subject: Reply with quote
I'm 5' 8" and can ride the vara quite comfortably with preload set to seven as I discovered the other day. It's not as high as you think.
Sherwood Bambi
PostPosted: 11:32 - 24 Jun 2012    Post subject: Re: Minimum inside leg for a Varadero 125? Reply with quote
HTH Thumbs Up[/quote]
Funny I hadn't seen any references at all to this site - thanks for the links ! Very interesting as I'm vertically challenged myself and have been thinking about a sports tourer like the Triumph Sprint ST. Sat on one the other week which had the seat contoured for a shorter rider and it felt pretty comfortable even without a lowering kit.
The last post was made 13 years, 281 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.52 - MySQL Queries: 13 - Page Size: 86.79 Kb
