Smallest 12v battery possible?
phil0185
PostPosted: 16:45 - 23 Jun 2012    Post subject: Smallest 12v battery possible? Reply with quote
I'm converting a bike from 6v to 12v.
The current 6v battery is:
70mm long
70mm wide
95mm high
I can modify the bay to accept a longer battery but only up to 100mm in height. Therefore the Yuasa Yumicron YB2.5L-C, which is:
80mm long
70mm wide
105mm high
...will not be suitable.
The best one I can find at the moment is the Yuasa Yumicron YB4L-B, which is:
120mm long
70mm wide
92mm high
Does anyone know of a 12v battery which is closer to the original 6v battery dimensions? Remember, it can't be higher than 100mm! Sealed lead acid suggestions also welcomed.
PostPosted: 17:06 - 23 Jun 2012    Post subject: Reply with quote
Depending on your budget, you could go Lithium :-
https://www.ebay.co.uk/itm/Gilera-Freestyle-E-Starter-Shorai-Lithium-Standard-Motorcycle-Battery-LFX09A2-/200740613944?pt=Motorcycles_Parts_Accessories&hash=item2ebd12af38
113x58x89mm. Pricier, but also a lot lighter, higher cold start cranking amps, charges faster and lasts longer.
[edit] Cheaper, and as there's no acid I can't see why it couldn't be mounted on its side (61x61x112mm) :-
https://www.ebay.co.uk/itm/2004-2009-Honda-CRF250X-Ballistic-EVO2-4-Cell-Lithium-Motorcycle-Battery-NEW-/310404615616?pt=Motorcycles_Parts_Accessories&hash=item48458e8dc0
The last post was made 13 years, 363 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.11 - MySQL Queries: 13 - Page Size: 32.36 Kb
