Chrome Spray paint? And footpegs
EazyDuz
PostPosted: 21:23 - 24 Jun 2012    Post subject: Chrome Spray paint? And footpegs Reply with quote
Is it possible to re-chrome plastic? Just a chrome spray paint kind of thing? Any particular brand?
Also my bikes footpegs are helt on the shaft with a bent bit of metal wire, i dont know the correct term for it but they are often used on axles just as a failsafe if the nut came loose.
I just wondered how to remove it, ive pulled it with pliers as hard as i can and it wont come out, do you have to cut them and replace them?
Thanks
hazza
PostPosted: 21:46 - 24 Jun 2012    Post subject: Reply with quote
A cotter pin?
https://i1239.photobucket.com/albums/ff501/harrybarfield/Cotter_Pin.jpg
You have to straighten out the bend first then pull through with pliers. If it wont budge then just bost it off and get a new one, they are 10 a penny.
Chrome spray pain dosent work. Its just silver really unless they have changed it.
Rowey
PostPosted: 22:05 - 24 Jun 2012    Post subject: Reply with quote
This stuff:
https://www.diy.com/nav/decor/paint/specialist-paints/spray_paints/Plasti-kote-Fast-Dry-Enamel-Aerosol-Chrome-Effect-100ml-9254089
Is rubbish, it looks nothing like chrome, more a metallic silver. If you lacquer it to make it durable then it makes it go dull grey.
I've heard it can be done with another product but requires a lot of time, prep and a decent airbrush.
You used to be able to get chrome plating kits from ebay for not a lot of money. They're good for little parts. You'll need to paint plastics with a zinc primer first but it can be done fairly easily.
ZX6R C6F.
EazyDuz
PostPosted: 23:32 - 24 Jun 2012    Post subject: Reply with quote
They are 2 side panels about 8x6" which are chromed but they are scratched and pitted.
What is the cheapest method to re-chrome them?
The last post was made 14 years, 96 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.79 - MySQL Queries: 13 - Page Size: 39.59 Kb
