125 2T - 25 bhp max - 13 - 38 ?
WannaBeDude
PostPosted: 08:47 - 25 Jun 2012    Post subject: 125 2T - 25 bhp max - 13 - 38 ? Reply with quote
Will this ratio work -
Original 14 - 43
Mitos - 14 - 40
https://www.ebay.co.uk/itm/Cagiva-Raptor-125-03-11-New-steel-JT-front-sprocket-13-tooth-JTF711-13-/400259288251?pt=UK_Motorcycle_Parts&hash=item5d31500cbb
Have renthall 38 rear, and this is a cheap way to get what i need.
Karma Thumbs Up
PostPosted: 09:31 - 25 Jun 2012    Post subject: Reply with quote
What do you want to achieve?
WannaBeDude
PostPosted: 10:02 - 25 Jun 2012    Post subject: Reply with quote
More exceleration on the cheap, rear is newish, and chain still in good nik .....
Rather than having to pay 100 plus on new whole lot.
Put the 38 on rear but would prefer 39 - got the 38 for 20 quid, and fitted when doing other job so was easy .. Thumbs Up
lihp
PostPosted: 10:06 - 25 Jun 2012    Post subject: Reply with quote
You will likely need to shorten the chain if you make sprocket smaller. So factor in a new link and tools.
PostPosted: 10:12 - 25 Jun 2012    Post subject: Reply with quote
Well the ratio you would have with 13-38 would give you less acceleration than standard.
You want to lower the front and raise the rear. Every tooth you drop on the front is roughly equivalent to raising the rear by 3.
WannaBeDude
My mechanic will shorten it and fit it all for 20 - 30 max - aswell as do a couple of other checks i want him to. He's great. Thumbs Up
PostPosted: 10:15 - 25 Jun 2012    Post subject: Reply with quote
It's simple
take the front and divide it by the rear.
13/38 = 0.342
14/43 = 0.325
That number is how much the rear sprocket turns with one turn of the front. The smaller that number the higher the acceleration.
WannaBeDude
PostPosted: 10:20 - 25 Jun 2012    Post subject: Reply with quote
Will it be around the same change as going to 14 39 or 40 there abouts .. other wise its not worth doing ... your figure seems a bit too small to my lamen head. Thumbs Up
PostPosted: 10:24 - 25 Jun 2012    Post subject: Reply with quote
That would be even worse (for acceleration).
14/40 =0.35
You want less than 14 on the front and/or more than 43 on the back.
WannaBeDude
PostPosted: 10:30 - 25 Jun 2012    Post subject: Re: 125 2T - 25 bhp max - 13 - 38 ? Reply with quote
Original 14 - 43
Mitos - 14 - 40
Current is 14 - 38 ----
PostPosted: 10:32 - 25 Jun 2012    Post subject: Reply with quote
Stock gearing 70mph at X Revs
13/38 73.5mph at X Revs
14/40 75.25mph at X Revs
13/43 64mph at X Revs
WannaBeDude
PostPosted: 10:36 - 25 Jun 2012    Post subject: Reply with quote
I have on NOW 14 38 .... was gonna stick 13 on front, to get a bit more exceleration and a more usable 6th gear ? sorry if i,m being true to form and being a bit dim ... Confused Thumbs Up
PostPosted: 10:52 - 25 Jun 2012    Post subject: Reply with quote
13/38 would give more acceleration than 14/38, but still less than standard.
WannaBeDude
PostPosted: 10:58 - 25 Jun 2012    Post subject: Reply with quote
I in future will be getting 14 39 - maybe 40 --- and thought that 13 - 38 may be the same as 14 39/40 there or there abouts .. if i'm right i'll do it, but would be wrong to bother if i'm wrong.
Think i need kickstarts graph - again Rolling Eyes Karma
PostPosted: 11:25 - 25 Jun 2012    Post subject: Reply with quote
13-38 is closest to 14-41
WannaBeDude
PostPosted: 11:28 - 25 Jun 2012    Post subject: Reply with quote
Well that will do and will also give me more idea on whether i want 39 - 40 - even 41 - long term ... Karma
Appreciate you patience and help big fella. Karma Thumbs Up
P.
PostPosted: 14:44 - 25 Jun 2012    Post subject: Reply with quote
You want a 13/62 Thumbs Up Laughing
WannaBeDude
PostPosted: 16:00 - 25 Jun 2012    Post subject: Reply with quote
I,ll ask chris to run it through his head calculator Idea Thumbs Up
The last post was made 13 years, 231 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.56 - MySQL Queries: 13 - Page Size: 99.82 Kb
