Backfiring / carb adjustment
proximity
PostPosted: 21:31 - 11 Oct 2004    Post subject: Backfiring / carb adjustment Reply with quote
Hi i just got my new bike (K reg Yamaha SR) and had to clean the carb before it would start. After this my dad adjusted the carb so that it would run better, but it has started to backfire like when i throttle off for a junction etc. Sometimes it can be quite loud. I think the problem is too much fuel in the mixture, am i correct?
Next question, to reduce the fuel in the mixture do i want to turn the mixture screw in or out? The default is 1-1.5 turns out. Does the idle screw make any difference or is that just the speed that it idles at.
Any help is appreciated.
Jay
Scooby
Scrappy Doo
PostPosted: 21:38 - 11 Oct 2004    Post subject: Reply with quote
Idle screw is just that, the idle speed. Does not affect the bike in any other way. I would suggest putting the mixture screw back to the factory recommended settings. Has your dad had any mechanical experience or is he just poking around? He might be doing more damage than good, even though his intentions are good.
Finglonga
PostPosted: 22:14 - 11 Oct 2004    Post subject: Reply with quote
Sounds like you have an air leak somewhere on the exhaust.
Andy Sez....
F.Y.Y.F.F.
proximity
PostPosted: 23:12 - 11 Oct 2004    Post subject: Reply with quote
There is a hole on the bottom of the exhaust, its like a really small one that looks like it has been drilled, i would say about 3mm diameter. It is just before the pipe starts to cone out.
Any idea which way the screw goes for less fuel then?
mr jamez
PostPosted: 23:22 - 11 Oct 2004    Post subject: Reply with quote
You have the default value, so tighten the screw as far as it will go (don't force it round, when you feel it pinch stop turning) then wind it out to the specified amount.
Fill the hole on the exhaust with something like 'metalweld' you can get it from halfords, its just like a glue really.
proximity
PostPosted: 23:37 - 11 Oct 2004    Post subject: Reply with quote
I will do that, say 1.25 turns, thats between the defaults. So should the hole not be there? Can anyone with an SR confirm this?
Jrod
Page 3 Girl
PostPosted: 23:42 - 11 Oct 2004    Post subject: Reply with quote
Don't fill the hole, Neutral That's for water to come out of!
proximity
PostPosted: 23:53 - 11 Oct 2004    Post subject: Reply with quote
Good job you cleared that up before i went out and filled it in the morning Very Happy
I know you all recommend the default setting but im sure thats what my dad set it to when it was backfiring, hence wanting to know which way it goes for less fuel.
mr jamez
PostPosted: 23:57 - 11 Oct 2004    Post subject: Reply with quote
If the screw is on the engine side of the carb then it is a mixture screw, turn it anti clockwise to richen the mixture, other way to lean it off.
If it is on the air box side then it is an air flow adjustment screw, anticlock wise to to lean it off, clockwise to richen.
proximity
PostPosted: 00:12 - 12 Oct 2004    Post subject: Reply with quote
I have attached a diagram i drew of my carb, looks to be definately the engine side one but just to make sure.
Dom_
Points Mean Prizes
PostPosted: 00:38 - 12 Oct 2004    Post subject: Reply with quote
You sure it was a backfire mate??
Not just popping and fuel igniting in the exhaust on the overun?
Jrod
Page 3 Girl
PostPosted: 01:01 - 12 Oct 2004    Post subject: Reply with quote
proximity wrote:
Good job you cleared that up before i went out and filled it in the morning Very Happy.
Brick Wall
proximity
PostPosted: 01:02 - 12 Oct 2004    Post subject: Reply with quote
Yes it was popping! I thought backfiring was just what it was called or is that a completely different thing Confused oops, Sorry for any confusion
swampy
PostPosted: 01:05 - 12 Oct 2004    Post subject: Reply with quote
Backfiring sounds like a large bang often accompanied by a lurch in the bike, if it goes popopopopopoopop when you let off the throttle then thats over run and should be ok Thumbs Up
proximity
PostPosted: 10:51 - 12 Oct 2004    Post subject: Reply with quote
Ok good, there is no lurching like you said so this is normal and nothing needs adjusting? I think it only does it when its cold.
The last post was made 21 years, 314 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.74 - MySQL Queries: 13 - Page Size: 82.35 Kb
