| J.M. |
 J.M. World Chat Champion
 Posted: 15:56 - 30 Jun 2012 Post subject: Faulty regulator? |
I noticed it last night really.
I notice in the morning when I start the bike that the lights pulse a little. Once I'm riding this pulsing generally goes away. The pulsing is seen in all lights; idiot, tail, front, dash.
Also when I started the bike the other day with wet gloves on a fairly cold day, I went to turn on the heated grips and the blue light flashed, which means that the voltage is too low to power the grips. I gave it a bit of throttle whilst stationary for a few seconds and the flashing went away and the pulsing of the lights also stopped.
The main thing that I noticed though, and this one surprised me, I was picking up my friend last night to bring her back to mine. Empty road, no external lights, good road surface, know it like the back of my hand. Was probably going around 80 to 90 and 8 miles in to a 10 mile journey. Looking down at the dash I notice that the brightness of the backlight is pulsing slightly. Not by a large amount but it was noticeable. At that sort of speed, I would have thought that I could have a flat battery and the bike would be fine?
The battery is just a few weeks old. The bike starts first try every morning since having this battery.
Also, when I got caught out in that freak storm the other day with hail the size of tennis balls (I'm not exaggerating, cars got dented in Hinckley, thankfully it wasn't so bad where I was!), after riding for a while in the cold and the rain, my engine at one point when I gave it throttle felt like it wanted to cut out.
I pulled over, raised the idle a little bit (now idles at about 1.5k) and revved the bike up whilst stationary. Couldn't sense anything bad at all and riding off after that, everything was fine. When going through flood waters the engine again felt a little sluggish; giving it high revs for a few seconds after sorted the problem though. It's started perfectly every time since that though so I'm not too worried. I must have done around 100-150miles since riding through the flood water on 4 or 5 different journeys; I've not felt it happen again.
Does it sound like a faulty regulator to you guys? I don't have a spare to test, I'll have to buy one if it is, hence asking before purchasing anything. ____________________ 2004 R1 & 2018 XSR900 |
| The Shaggy D.A. |
 The Shaggy D.A. Super Spammer
 Posted: 16:06 - 30 Jun 2012 Post subject: |
Get your multimeter out and check the voltages, before your fry your new battery. This is from my CB500 workshop manual, but the concept would be the same for a GS500. With revs about 5k, you shouldn't be getting more than about 15v. My regulator was duff, I was getting 17-21v, and after about 2 minutes of running all my lights would dim. ____________________ Chances are quite high you are not in my Monkeysphere, and I don't care about you. Don't take it personally.
Previously : CB100N > CB250RS > XJ900F > GT550 > GPZ750R/1000RX > AJS M16 > R100RT > Bullet 500 > CB500 > LS650P > Bullet Electra X & YBR125 > Bullet 350 "Superstar" & YBR125 Custom > Royal Enfield Classic 500 Despatch Limited Edition (28 of 200) & CB Two-Fifty Nighthawk > ER5 |
| J.M. |
| Teflon-Mike |
 Teflon-Mike tl;dr
 Posted: 16:19 - 30 Jun 2012 Post subject: |
We talking the GS here Jord?
When you rebuilt the front end, did you check the yokes & headstock area carefully?
lock-stops, after a spill like yours lock stops can get slightly bent, & that can mean the forks go a bit 'too' far one side or other, and that can trap the wires going through the yoke.
loom through the joke, in plastic sleeving.... bike goes down, forks trap the loom.... wires can get stressed and tug from connectors, but soon as bike picked up, stress removed they 'go back' and unseen in sleeving you wont necesserily spot a stressed connection, that then goes 'intermittent'.
though the reg/rect was tatered on the 750, and its a '93 Honda renowned for the regulators frying...
Eventually traced a stressed wire!
And yup, my old buss has been DTR at some point in its life AND was co-incident with a bent lock-stop!
Spent £45 on a ruddy Reg/Rect for the sake of a 45p spade connector!
NEVER jump to conclusions......
Also DONT dismiss the battery JUST becouse its new....
Check that too...
Where did you get it? Did it come 'dry'? Did you fill with propper acid or common error, distilled water? ____________________ My Webby'Tef's-tQ, loads of stuff about my bikes, my Land-Rovers, and the stuff I do with them!
| J.M. |
| J.M. |
| orac |
 orac World Chat Champion
| AlexW |
 AlexW Spanner Monkey
| orac |
| J.M. |
| orac |
| AlexW |
| J.M. |
| The Shaggy D.A. |
 Posted: 15:54 - 01 Jul 2012 Post subject: |
Depends on the style, some need to be bolted on to help dissipate heat, others are just happy in a rubber mounting. Either way, floating around loose isn't good for the connections  ____________________ Chances are quite high you are not in my Monkeysphere, and I don't care about you. Don't take it personally.
| J.M. |
 Posted: 16:11 - 01 Jul 2012 Post subject: |
Definitely should have been bolted on.
Just took off the rear side panels to take a proper look. The bracket has those nut fixings on the back for a bolt to go in. Also reg/rec seems to have markings left by a washer/bolt that was there once upon a time.
Best get looking in the bits and bobs box to see if I have something that fits!
Edit: That's bolted on now. Can anyone confirm that it's definitely the reg/rec? I don't have another to try, so to try one I will have to buy one. Being currently jobless; spending money is not my top priority.  ____________________ 2004 R1 & 2018 XSR900 |
| orac |
| J.M. |
| AlexW |
| J.M. |
 Posted: 20:50 - 02 Jul 2012 Post subject: |
Ordered one from eBay used for £30. It's more than I would have liked to have paid for a used one, it's cheaper than waiting it out and needing a new reg/rec and a new battery though.
Hopefully it'll be here in a few days and I'll get to try it. I've got quite a few miles to do between now and then though. Probably 100-200 tops.
If overheating causes it then, I can't help but wonder whether having a pillion could have caused it. I've done quite a lot of pillion miles recently. There's an air vent right next to the reg/rec on the bike, but it's in a spot where a pillion's legs could very well cover the air vent; blocking air in to the bike which could cause the air around the reg/rec to heat up causing the reg/rec to overheat? Pic attached below of what I mean.
I've drawn the pillion a little far forwards. When sitting properly the leg would cover the vent.
There should be room to wire in a fan, I'll have a look to see if there are any knocking around. I see that some people seem to drill holes in the reg/rec, like this: https://www.ducati.ms/forums/attachments/sport-classic/51048d1247288769-voltage-rectifier-regulator-fin-mod_szd.jpg ____________________ 2004 R1 & 2018 XSR900 |
| orac |
| J.M. |
| orac |
| J.M. |
| orac |
| J.M. |
The last post was made 13 years, 231 days ago. Instead of replying here, would creating a new thread be more useful? |
