| stuartadair |
 stuartadair Crazy Courier
| Ariel Badger |
 Ariel Badger Super Spammer
 Posted: 19:14 - 01 Jul 2012 Post subject: |
If water has entered the chamber it can hydraulic... bending valves, breaking rings and bending con-rods. Time to take the head off I had it happen on a 500cc Armstrong, all it had done was loosen some carbon that held the Exh valve open  ____________________ Bikers make great organ donors, get 115 on your licence today. |
| lihp |
 lihp World Chat Champion
| stuartadair |
| stuartadair |
| lihp |
| stuartadair |
| moonzoomer |
 moonzoomer World Chat Champion
| prawny1 |
 prawny1 World Chat Champion
| stuartadair |
| moonzoomer |
| stuartadair |
 Posted: 12:55 - 05 Jul 2012 Post subject: |
Hello all
I've just got chance to start looking at this engine. Took the crank cover off to see the crank timing mark and the water pump off to see the cam mark. According to the manual I have the mark on the crank aligns with a fixed mark on the cover to show TDC, and at the same time a mark on the cam aligns with a mark on the cam cover.
I found 2 marks on the crank, a single and a double mark so I'm not sure which is the correct one - Can someone please advise.
However, when the single mark is aligned the cam mark seems to be off its mark, and its worse when I align the double mark.
This photo is with the sinle crank mark aligned. The cam mark should be in the V on the cam casing cover.
Has anyone had these engines to bits before and can advise on the crank marks and if its normal to see the cam aligning in this way ?
Have a compression tester coming tomorrow to be 100% sure I've got issues in this area.
https://i997.photobucket.com/albums/af99/stuartadair123/IMG-20120705-00073.jpg |
| stuartadair |
| P. |
 P. Red Rocket
 Posted: 15:15 - 05 Jul 2012 Post subject: |
get.
the.
head.
off.
Saves ALL the guess work You'll soon see if a valve has been introduced to the piston. |
| stuartadair |
 Posted: 15:17 - 05 Jul 2012 Post subject: |
I know you're right Paddy, I'm just trying to find any possible other solution in the hope it all goes away  |
| P. |
 P. Red Rocket
 Posted: 16:46 - 05 Jul 2012 Post subject: |
| moonzoomer |
| stuartadair |
| moonzoomer |
| russell210276 |
 russell210276 Renault 5 Driver
 Posted: 20:00 - 05 Jul 2012 Post subject: |
just a quick 1 from me 1 simple thing has been missed but im no expert you said water was in the air box what about cleaning the throttle body incase the fuel has water mixed or am i thinking wrong with me been use to carbs if so ignore me  |
| stuartadair |
| stuartadair |
| ThoughtContro... |
 ThoughtContro... World Chat Champion
| stuartadair |
| P. |
 P. Red Rocket
 Posted: 12:55 - 07 Jul 2012 Post subject: |
NO WAY!
The last post was made 13 years, 172 days ago. Instead of replying here, would creating a new thread be more useful? |
