2 Thundercat things..
PostPosted: 18:57 - 03 Jul 2012    Post subject: 2 Thundercat things.. Reply with quote
2 issues with the Thundercat currently.
I was doing silly speeds this morning on the way in Shifty and noticed my front wheel likes to wobble slightly at anything past 120. Like when you accelerate too fast and it wobbles a bit, but under smooth acceleration, advancing to 140 or something...
Not so much an issue as this isn't a usual thing, but I was following the road which bears right at about 130-140, open 3 lane motorway, empty as empty can be and it just felt a bit wobbly, very lightly but enough to make me query it. Pressures are spot on when cold, tyres are round and head bearings were deemed excellent on the MOT. Its more a weaving wobble if you get what I mean...
Possible steering damper needed?
Another issue.
Is roll on acceleration from 100mph in 4th meant to be fast in anyway. Put it this way, I got dicked on by an 1.8 Audi A4, 4 door saloon...he was pulling away from me from 100mph down a hill in 4th with me on full throttle, caught and overtook went into 5th and 6th and slowed down and continued my journey home.
Just thought, really? Is it that bad?! I'm used to seeing a car fly up to the side of you, opening throttle and eating them, piece of cake! Thinking
As stated its not a daily occurrence but it got me thinking today! Karma
J.M.
PostPosted: 19:08 - 03 Jul 2012    Post subject: Reply with quote
I'll swap you for the GS? With the charging fault I have to rev the nuts off of it whilst riding so that I don't run out of battery and stall. Laughing
It's been ages since my speedo got in to triple digits. Sad
2004 R1 & 2018 XSR900
Michael47
PostPosted: 19:16 - 03 Jul 2012    Post subject: Re: 2 Thundercat things.. Reply with quote
Another issue.
The wobble - not sure, was there any wind / did it happen before on a different stretch?
The cat likes revs .. and in 4th doing 100 you'll be too far from max torque - having said that, not had the same problem on my beemer no matter what gear Wink
Q: Why Michael47? A: 0-46 was taken!
PostPosted: 19:31 - 03 Jul 2012    Post subject: Reply with quote
No wind.
Do that route daily, obviously not always high speed but on occasions it seems like it gets a bit loose on most roads around that speed..
evoboy
PostPosted: 19:33 - 03 Jul 2012    Post subject: Reply with quote
Its not a more modern GSXR. It wont be anywhere near as stable as one.
Accept it for what it is.
APT Motorcycles
KDub
PostPosted: 19:35 - 03 Jul 2012    Post subject: Reply with quote
Are the wheel bearings okay?
Or has a wheel balance weight fallen off?
PostPosted: 20:25 - 03 Jul 2012    Post subject: Reply with quote
I know its just a usual faired commuter for me. It handles well enough for me to have a play Smile It just feels slightly iffy up the higher speed end.
Wheels look ok, current weights still stuck nice Thumbs Up
weasley
PostPosted: 20:38 - 03 Jul 2012    Post subject: Reply with quote
You don't need a steering damper on a Cat. The steering geometry is rock stable; I've had a couple of really close calls with the front, saved by the bike's inherent stability rather than my God-like riding skills. In 10 years I have had one steering headshake, and that was accelerating hard over a badly rippled road surface. I would suspect head bearings or something else before looking at unnecessary bolt-ons. Of course, if you have jacked up the rear end or dropped the front then all bets are off.
It really should pull hard under the conditions you mention. The Cat is more a mid-ranger than a top-ender so it sometimes pays to shift before the red line as the last 1,000 rpm or so isn't always worth it. Always worth pulling out my favourite fact: the Cat has more peak torque than every R6 that has followed it (but significantly less peak power, so it shows revs are not what it feeds on).
Wave2k
G's Stalker
PostPosted: 20:44 - 03 Jul 2012    Post subject: Reply with quote
Check the tyre and its sidewalls.
I once had a bubble on the sidewall of my car that made it shake, it eventually blew out on the motorway.
When my Sp1 caught fire on the motorway i only realised because it started to shake.
I think the heat began to heat the tyre and thus upping the pressure and making it unstable.
The whole rear of the bike was scorched and melted anyway lol.
Ducati 1299 Panigale
2009 Corvette C6 z51
The last post was made 14 years, 137 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.07 Sec - Server Load: 0.29 - MySQL Queries: 15 - Page Size: 63.83 Kb
