cbr 600f problems
Lyam
PostPosted: 17:18 - 04 Jul 2012    Post subject: cbr 600f problems Reply with quote
today whilst riding the bike it was running out of power and cutting out when i applied the throttle at low revs, eg 2nd gear 3k apply throttle bike just starts slowing down and cuts out, if i pull the clutch in it cuts out immediately and i have to rev the shit out it before letting the clutch out almost as if it has an intermitent flat spot?
Casper
PostPosted: 17:52 - 04 Jul 2012    Post subject: Reply with quote
Look for air leaks round the carb rubbers, In and out side of the carbs. Have you had the carbs cleaned latley? Reason i ask is i had the same problem and it turned out to be my pilot jets, two vibrated loose and were sitting in the float bowls.
dextersaurus
PostPosted: 20:35 - 04 Jul 2012    Post subject: Reply with quote
As above, i had the same sort of problem when the jets were loose. i'd take the carbs off and have a look. not too difficult to take them off on the CBR anyway!
Casper
PostPosted: 20:59 - 04 Jul 2012    Post subject: Reply with quote
You got yours fixed yet?
Lyam
PostPosted: 06:21 - 05 Jul 2012    Post subject: Reply with quote
it does it intermitently now soetimes the bikes fine sometimes you go to pull away and unless the rpms at 6k it just stalls, ive no idea about jets etc i have a haynes manual will see f i can fix with the help of that
The last post was made 13 years, 222 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.72 - MySQL Queries: 13 - Page Size: 42.59 Kb
