performance after restriction
Hog
PostPosted: 06:41 - 05 Jul 2012    Post subject: performance after restriction Reply with quote
Hi all, newby here...am thinking of buying a H-D Road King (1600) but as not yet got big bike license will have to restrict it. Does anyone have experience of how this may alter the performance of the bike?
Cheers Hog
hmmmnz
PostPosted: 07:00 - 05 Jul 2012    Post subject: Reply with quote
probably not to bad actually, max torque is at 3250rpm,
and you get about the 33hp limit it those revs any way
you are aware that they weigh nearly 400kg!!!
wouldnt be my learner bike of choice, but each to there own,
myself id be looking at an old bandit 600, something that will take a crash easily, and parts are plentiful and cheap,
good luck Thumbs Up
the humans are dead
I kick arse for the lord
Itxi
PostPosted: 08:07 - 05 Jul 2012    Post subject: Reply with quote
I thought there was still a maximum engine capacity even if they were restricted?
Hastings Direct, Scum you say?
_matt
PostPosted: 08:14 - 05 Jul 2012    Post subject: Reply with quote
https://www.1stopinstruction.com/a2restrictedlicenceeastlondon.html
according to that, it says "regardless of engine size" so i dont think it's limited.
I wonder, if you have an older bike, if you get it tested on a rolling road (my local garage has one) and it turns out that enough horses have escaped from the engine over the years that it's under 33bhp (even if, brand new, it'd be say, 50bhp), does it still need restricting? Cos technically it'd be under 33bhp, even if it's not meant to be
1990 Yamaha XV 535 (Alive Again!) / 2007 Jinlun Texan 125-11 (formerly 2k3, wrong details, now going rusty in the back garden )
PostPosted: 09:13 - 05 Jul 2012    Post subject: Reply with quote
There's nothing, not any hint, in the current law about any requirement to have a bike restricted. All that matters is whether it is or isn't capable of producing a "net power output" of over 25kW (or 0.16 kW/kg...)
Nope. There's a maximum power-to-weight[1] of 0.16 kW/kg, so a bike nudging the 25kW power limit can't weigh less than 156.25kg[2].
I'm led to believe that a Road King might weight very slightly more than that... Wink
Note that it's presto-chango with the new categories next year[3], but that won't effect existing A<=25kW holders.
[1] It would be technically correct - the best kind of correct - to call it power-to-mass, since it's specified in kg.
[2] “power to weight ratio”, in relation to a motor bicycle, means the ratio of the maximum net power output of the engine of the vehicle to its weight (including the weight of any side-car) with—
(a) a full supply of fuel in the tank,
(b) an adequate supply of other liquids needed for its propulsion, and
(c) no load other than its normal equipment, including loose tools;
[3] Category A1:
— motorcycles with a cylinder capacity not exceeding 125 cubic centimetres, of a power not exceeding 11 kW and with a power/weight ratio not exceeding 0,1 kW/kg,
— motor tricycles with a power not exceeding 15 kW
Category A2:
— motorcycles of a power not exceeding 35 kW and with a power/weight ratio not exceeding 0,2 kW/kg and not derived from a vehicle of more than double its power
PostPosted: 09:24 - 05 Jul 2012    Post subject: Re: performance after restriction Reply with quote
Cheers Hog
You do realise you'll have to have a full license to ride any bike over 125cc right?
supZ
PostPosted: 09:54 - 05 Jul 2012    Post subject: Reply with quote
i call tarp.
and lol the thing only makes about 56-66hp anyway.. my god it must barely move.
CBR954RR - Daily toy
CBR600RR - Trackbike
The last post was made 13 years, 217 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 1.06 - MySQL Queries: 13 - Page Size: 54 Kb
