VFR800 - Vague front end?
95Theses
PostPosted: 22:02 - 05 Jul 2012    Post subject: VFR800 - Vague front end? Reply with quote
I'm not even sure vague is the right description.
I've had a '99 VFR800 for a year and put 12k miles on it (19>31)
It's never missed a beat, but the last couple of hundred miles the front end feels strange, sort of light.
Low speed corners it wants to turn the bars into the corner, almost like I'm steering it around instead of leaning through the bend. If I hit a bump cornering, the bars give a bit of a shake instead of just absorbing it. It feels flighty and a bit unstable under cornering, enough that I'm tootling around bends instead of driving through them because I don't trust it not to drop right into the bend.
The only time I've felt it anything like that before was when I had a nail in the rear and the soft back tyre was making it feel a bit similar.
I've carried a pillion quite a bit and I thought it might be the rear shock on the way out making the rear sit low and the front high, but equally I thought it might be the head bearings.
Basically I've no idea what it is as I've no experience on maintaining a bike so don't know where to start looking for what to fix.
What could it be, and how do I check it?
Thanks
moonzoomer
PostPosted: 22:08 - 05 Jul 2012    Post subject: Reply with quote
Could be a number of things, worn or incorrectly adjusted suspension and/or suspension linkages front and rear, worn or non suitable tyres, worn wheel bearings or headstock bearings, some models have linked brakes that give problems so imo its a process of Elimination until the fault is found.
PostPosted: 22:13 - 05 Jul 2012    Post subject: Reply with quote
First things first, tyre pressures.
95Theses
PostPosted: 22:14 - 05 Jul 2012    Post subject: Reply with quote
Thanks
Matching pair of Angel ST's on it with about 800 miles on them, pressure is fine on both - checked yesterday.
Haven't adjusted the suspension so can't be incorrect adjustment - could well be worn as I suggested, but no idea how to check aside from what I've done so far - bounce it up and down a bit on and off it and go 'That feels about right'!
Mine does have linked brakes, but brakes feel fine and it feels stable under heavy braking
Looking for a suggestion for where to start looking (as in whats most likely) and how to go about checking it if someone can help.
moonzoomer
PostPosted: 22:36 - 05 Jul 2012    Post subject: Reply with quote
Check the anti dive link mechanism for free movement, if I remember right its the front left caliper that moves up and down on a pivot bracket on your model, this in turn transfers brake fluid to the rear caliper to steady the bike. The moving bracket has a plunger cylinder that is prone to seize and grow up so check this for free movement by pushing the bike forward and applying the front brake, the mechanism should move slightly activating the pushrod and then the back brake. If this mechanism is seized or semi seized it can apply the back rake without you knowing possibly causing the handling problem you have encountered. This is a reasonably common on older Honda Blackbirds with a very simiiar system.
temeluchus
PostPosted: 01:43 - 06 Jul 2012    Post subject: Reply with quote
Few things to look for in no particular order.
Tyres ok? Plemty of tread, no crazy paving?
Is there any oil in the forks? Are they damping properly, no signs of any leaks?
Wheel bearings ok(front and back)? On the centrestand give both wheels a good wiggle, check for any play.
Swingarm bearings ok? As above, give the swingarm a good yank to see if there is any side to side movement.
Fork or forks bent? Bottom yolk bent?
Wheel warped(front and back)?
Suspension linkage bearings ok? Check for vertical play in the suspension.
Suntan Sid
PostPosted: 05:08 - 06 Jul 2012    Post subject: Re: VFR800 - Vague front end? Reply with quote
Tyre pressure, no question!
Barnaby This post is not being displayed because the poster is banned. Unhide this post / all posts.
iooi
PostPosted: 05:25 - 06 Jul 2012    Post subject: Reply with quote
95Theses wrote:
Thanks
Haven't adjusted the suspension so can't be incorrect adjustment - .
Was it like this before you changed the tyres ??
If not could just be how the tyres react, or possibly the spindles are not tightned up.
I swopped from Avon Distenza to PR3's and have had to soften the suspension right off to get any thing like a good handling.
prawny1
PostPosted: 08:18 - 06 Jul 2012    Post subject: Reply with quote
often on bike rear suspension/wheel play can be mistaken for front end issues, check the swing arm and wheel bearing for play.
also notchy steering head bearings can cause you to unknowingly apply greater preasure to turn the bike so steering can feel almost exaggerated and will not want to self centre properly, to check for play hold your hand round the frame/upper steering pivot and rock the bike withe the brakes on.
to check for notches put the bike on the centre stand and take the weight off the front wheel, then turn the bars lock to lock.
hellkat wrote:
anthony_r6
PostPosted: 08:53 - 06 Jul 2012    Post subject: Reply with quote
This is EXACTLY what's happening to my Hornet. You've been able to describe the problems a lot more coherently than me! Thank You all, I'll hopefully be able to check all these too.
map
Mr Calendar
PostPosted: 09:12 - 06 Jul 2012    Post subject: Reply with quote
95Theses wrote:
...Matching pair of Angel ST's on it with about 800 miles on them, pressure is fine on both - checked yesterday...
Quick question - what pressure have you checked.
Only ask as tyre manufacturers recommended values can differ from bike majers values. The bike maker tests the bike with their approved rubber. So if that changes as is likely their values may not be valid.
Pirelli site if you click here.
Don't know the exact spec. of your bike but a quick check for VFR800 shows
Pirelli wrote:
FITMENT
120/70 ZR 17 M/C (58W) TL - 2.5 BAR FRONT
180/55 ZR 17 M/C (73W) TL - 2.9 BAR REAR
HTH Thumbs Up
PostPosted: 11:23 - 06 Jul 2012    Post subject: Reply with quote
Could your front brake be binding on slightly?
Any blueing on the disc etc?
anthony_r6
PostPosted: 17:05 - 07 Jul 2012    Post subject: Reply with quote
After you recommended this I decided to go take the brakes off and sure enough one of the pistons was sticking. Gonna take it on the motorway in a little bit and see if it's still wobbling at 70ish, but seems like this may be the cause.
Thank You! Karma
prawny1
PostPosted: 17:33 - 07 Jul 2012    Post subject: Reply with quote
Sticky caliper and motorway (any) riding = potential sudden wheel lock up
anthony_r6
PostPosted: 17:35 - 07 Jul 2012    Post subject: Reply with quote
Happened to me on a dual carriageway a couple of months ago lol
This isn't sticking my wheel, it was just constantly pressing against it.
I think I've solved it now, hence the test on the motorway 'cause it tends to shake a lot at 70ish (I don't have to DO 70 on the motorway, it is only a small stretch)
The last post was made 13 years, 165 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.67 - MySQL Queries: 13 - Page Size: 99.16 Kb
