Leaky fork seal?
GREENI3
PostPosted: 21:47 - 05 Jul 2012    Post subject: Leaky fork seal? Reply with quote
Recently noticed a film of oil and a few rings of dirt on the left fork.
Obviously it's not dripping oil or anything like that, but I'm having fork gaiters fitted next week, so would rather have the seals in good nick before putting them on.
The right hand stanchion is ok, but when I run my finger over the left one, I can feel the grease-like surface.
Is it worth worrying about?
Here's a few pictures:
https://s12.postimage.org/58seomg71/IMG_0151.jpg
https://s7.postimage.org/hwxt0qa17/IMG_0141.jpg
moonzoomer
PostPosted: 21:58 - 05 Jul 2012    Post subject: Reply with quote
Best replacing both sides at the same time since seals come in pairs, that oil leak is not minor and best dealt with before fitting gaiters and also check the levels of oil is the same in both forks. Now is the time to replace the seals as it will save you hassle and money later.
PostPosted: 23:10 - 05 Jul 2012    Post subject: Reply with quote
Theorist.
Source a piece of stiff plastic or a thin feeler gauge. Wiggle it down between the fork leg and the seal, and work it all the way round. Wipe fork leg clean. Re-evaluate issue.
moonzoomer
PostPosted: 00:31 - 06 Jul 2012    Post subject: Reply with quote
Rogerborg wrote:
Theorist.
Theorist??? No, the photographs show leaking forks which prove the fork seals are defective so hardly theory. If its broke fix it, if not dont bother but as it is in this case fix it which is just as cheap and hassle free to do in pairs as it is a single fork. Hiding or doing a botch job are hardly worth the hassle when you consider doing a proper job only costs a few quid and is not a big job compared to getting the forks reground and replated later.
temeluchus
PostPosted: 01:48 - 06 Jul 2012    Post subject: Reply with quote
The seals can be gummed up with crud, the suggestion is perfectly fine. Feeler guage will not damage the seal or hard chrome....
PostPosted: 08:59 - 06 Jul 2012    Post subject: Reply with quote
moonzoomer wrote:
Rogerborg wrote:
Theorist.
It would take less time to run something around the seal than it took to type all that.
pendulum
PostPosted: 09:23 - 06 Jul 2012    Post subject: Reply with quote
My CB500 forks leak a lot more than that and have done for a while (to my shame etc). I'd put it on the list of jobs to get done soon but I wouldn't worry about it as such.
1998 CG125 (Sold) CB500 [+ Clio 172]
Usually_Wrong: I tend to fail more than pass. [Speaking about Theory Practice]
Usually_Wrong: im on unemployment at the moment
kestrel
PostPosted: 10:02 - 06 Jul 2012    Post subject: Reply with quote
I'm with moonzoomer, replace the seals, particularly as the OP is having gaiters fitted which would prevent him from seeing if the leaks got any worse.
Front suspension isn't only there to give you a smooth ride, it also has the job of keeping the front wheel in contact with the road. Any deterioration in suspension efficiency also affects grip, braking and handling.
Fork seals and fork oil are cheap!
Isle of Man.........Road Racing Capital Of The World
GREENI3
PostPosted: 13:31 - 06 Jul 2012    Post subject: Reply with quote
I had a think about it and decided to have new seals fitted.
Considering that gaiters are going to be put on, I may as well renew the seals at the same time, so I'll know they should last a while.
Thanks for all your input though. Thumbs Up
Fizzer Thou
PostPosted: 13:40 - 06 Jul 2012    Post subject: Reply with quote
I have had a single fork seal weep on both my XR400 and my Exup1000.I used a 20' feeler gauge to 'wipe' between the fork seal and the leg after thorough cleaning of the area under the dust seal and this cured the problem on both bikes.This was 7,000 miles ago on the Exup and 2200 miles ago on the XR400.There was no noticeable deterioration in the handling from small amounts of oil that had been lost.
Always have a 'Plan B'
The last post was made 13 years, 183 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.35 - MySQL Queries: 13 - Page Size: 74.76 Kb
