| map |
 map Mr Calendar
 Posted: 12:59 - 04 Jul 2012 Post subject: What glue for fairing panel repair? |
Need to sort out some cracks and broken bits.
So need to glue together. I'll be putting some support at the back.
Glue will need to be heat and water resistant.
I did think about using filler type stuff but that would be probably OTT for the little bits I need.
So just wondered what people could recommend. Rather do that that than believe the packaging or some salesperson banter.
Thanks in anticipation  ____________________ ...and the whirlwind is in the thorn trees, it's hard for thee to kick against the pricks...
| Gazza M |
 Gazza M Crazy Courier
| duhawkz |
 duhawkz World Chat Champion
 Posted: 13:10 - 04 Jul 2012 Post subject: |
Plastech is pretty good, i have used it before.
https://www.bitzforbikes.co.uk/Plastech_Plastic_Repair_Kit-ref-11377-183.html
araldite or other epoxy types glue should work also, or you could try to weld it with an old soldering iron and use a tie wrap as a filler ____________________ "The guy is a worthless cunt and I honestly believe I would be a slightly happier person if he died." - Chris-Red |
| Slacker24seve... |
 Slacker24seve... World Chat Champion
 Posted: 13:16 - 04 Jul 2012 Post subject: |
Plastech is good, soldering iron and cable tie is better. ____________________ Triumph Daytona 675 track bike + girlfriend's Honda Hornet 600
Banger rallies are ace |
| stocksmenace |
 stocksmenace Scooby Slapper
| bryvw1973 |
 bryvw1973 Two Stroke Sniffer
| prawny1 |
 prawny1 World Chat Champion
 Posted: 20:56 - 06 Jul 2012 Post subject: |
If you're going to use superglue get it from a double glazing shop. You get a big pot for about £3 and it's slow-setting, gap-filling and very strong. ____________________ a.k.a 'Geri'
| hestonwfhdi |
 hestonwfhdi L Plate Warrior
The last post was made 13 years, 175 days ago. Instead of replying here, would creating a new thread be more useful? |
