Nut / bolt for connecting battery
kernow24
PostPosted: 16:50 - 09 Jul 2012    Post subject: Nut / bolt for connecting battery Reply with quote
Well I was installing an alarm so removed my battery and
'misplaced' the nuts / bolts that you use to connect the battery.
Anyone know what kind of buts / bolts ill need?
It for a battery like the one below, with the square terminals and take a little square nut and bolt
https://www.ebay.co.uk/itm/VARTA-YTX7A-BS-MOTORCYCLE-BATTERY-INCLUDES-ACID-PACK-/120924095299?pt=UK_Motorcycle_Parts&hash=item1c27a34343
got it bodged with some cable tis at the moment, but need to get
something more secure to connect it.
Marmalade
PostPosted: 17:01 - 09 Jul 2012    Post subject: Reply with quote
Should be something like an M10, maybe a small coach nut from B&Q will do it.
If it fits it's the right one is the right way to go with this one.
Quote Me Happy
PostPosted: 17:30 - 09 Jul 2012    Post subject: Reply with quote
I lost one the other day (which I later found) but in the mean time I took an angle grinder to a nut to make it square-ish. It's still on there and working fine.
keggyhander
PostPosted: 17:37 - 09 Jul 2012    Post subject: Reply with quote
The thread will be M6. I'd put money on it.
Marmalade
PostPosted: 17:52 - 09 Jul 2012    Post subject: Reply with quote
Yes. the M10 would be more suited to bolting a rack on . doh
AlexW
PostPosted: 18:15 - 09 Jul 2012    Post subject: Reply with quote
Something that small is likly to be M5.
Measure the hole on the termninal.
kernow24
PostPosted: 18:21 - 09 Jul 2012    Post subject: Reply with quote
Thanks for the responses.
Ive got some 8.5mm ring terminals on the wires at the moment,
which are slightly bigger than the terminal holes, so M6 sounds about right.
will have a look in B&Q tomorrow.
Something like this looks like it may work
https://www.diy.com/nav/fix/hardware/bolts/roofing_bolts/Roofing-Bolt-AVF-859250-Pack-Of-10-W-M6-x-L-20mm-9708660
although the square nuts look too big, the one that was on it was more of an oblong shape.
AlexW
PostPosted: 19:54 - 09 Jul 2012    Post subject: Reply with quote
File/grinder/grinding wheel, whatver you want to use to chop off your fingers, i mean, slim the nuts.
Raffles
PostPosted: 21:12 - 09 Jul 2012    Post subject: Reply with quote
https://www.ebay.co.uk/itm/ws/eBayISAPI.dll?ViewItem&item=140772466544&clk_rvr_id=362805834641&item=140772466544&lgeo=1&clk_rvr_id=362805834641&vectorid=229508
PostPosted: 21:40 - 09 Jul 2012    Post subject: Reply with quote
M6 nut and bolt on every battery I've seen. Any bike shop will have a pile of dead batteries you could nick the bolts off.
The last post was made 13 years, 264 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.05 Sec - Server Load: 1.33 - MySQL Queries: 13 - Page Size: 63.43 Kb
