| UnknownStuntm... |
 UnknownStuntm... World Chat Champion
| supZ |
 supZ World Chat Champion
 Posted: 10:54 - 11 Jul 2012 Post subject: |
flush it through, you dont want to empty it all out and then fill it back up. bit of a ball ache there.
an easy way is to open the res., attach a hose to the bleed nipple into a jar or something similar, then crack the nipple and pump the brake. as the res. gets low top it back up with fresh fluid. do this until you're only getting fresh out of the hose.. do the same with the other caliper to ensure all the old stuffs out.
then nip everything up and then bleed as normal to be sure.
personally i do it the other way (reverse bleeding) using a syringe and a bit of hose. i push fluid up through the bleed nipple, fill the res. then empty it. i do this until there is only fresh coming up in to the res. then top it up to the right level and job done. i sometimes bleed normally again just to be 100% but if done right it shouldnt be necessary,  ____________________ CBR954RR - Daily toy
CBR600RR - Trackbike |
| Vincent |
 Vincent Banned
| UnknownStuntm... |
| Vincent |
 Vincent Banned
| flumpy7 |
 flumpy7 Could Be A Chat Bot
 Posted: 17:46 - 11 Jul 2012 Post subject: |
If youre gonna empty the system completely i would reverse fill with a syringe when putting in the new fluid. Much quicker than all that pumping. Either that or use a mitivac to fill the system then bleed traditionally. Personally i haven't looked back since i first tried reverse bleeding/filling.  ____________________ 2012 Sinnis apache |
| carvell |
 carvell Scuttler
| Vincent |
 Vincent Banned
| carvell |
 carvell Scuttler
| stevo as b4 |
| supZ |
| UnknownStuntm... |
 Posted: 09:28 - 12 Jul 2012 Post subject: |
Well since the jury is split and unlikely to make a decision soon I'm just gonna pull out what I can from the reservoir with a syringe, fill that up with fresh, then crack the nipple with 2 banjos and wait till fresh stuff comes out, topping up as necessary, then tighten and do the other side.
To be fair, I've degunged the pistons both sides and there is a very small amount of pitting on some of them. Until I put new ones in, I think I'll just stick to bleeding the fluid through.
Cheers all  |
| Vincent |
 Vincent Banned
| jay12329 |
 jay12329 Dr. Evil
The last post was made 13 years, 234 days ago. Instead of replying here, would creating a new thread be more useful? |
