seals 2 stroke
russell210276
PostPosted: 13:45 - 12 Jul 2012    Post subject: seals 2 stroke Reply with quote
hi im getting no where with the gamma i am restoring just wont start for the life of it can anybody guide me how to replace the seals as i think its them that are leaking causing it not to start many thanks russ
suzuki rg gamma 1990
truslack
PostPosted: 13:55 - 12 Jul 2012    Post subject: Reply with quote
There are lots of seals, which in particular would you like to replace? Laughing
symonh2000
PostPosted: 14:02 - 12 Jul 2012    Post subject: Reply with quote
If it is the crank seals, which it sounds like it might be, it is an engine out and strip down job.
You will need to remove the barrel, split the engine cases, remove the crank and then do the seals.
The haynes manual should cover it. Smile
Four strokes is two strokes too many.
https://upload.wikimedia.org/wikipedia/commons/thumb/9/94/Seal_2012.jpg/220px-Seal_2012.jpg
https://www.bbc.co.uk/nature/images/ic/credit/640x395/g/gr/gray_seal/gray_seal_1.jpg
https://i.telegraph.co.uk/multimedia/archive/01661/seal_1661793c.jpg
russell210276
PostPosted: 15:00 - 12 Jul 2012    Post subject: Reply with quote
worst nightmare which Hayes manual do i need? is it 1 for the particular model of my bike?
russell210276
PostPosted: 19:28 - 12 Jul 2012    Post subject: Reply with quote
fuck me dry just started stripping the engine down removed cylinder from engine and petrol is pissing out id say 2 litres worth the crank case is full of fuel i think i found my problem i take it the carb is leaking fuel wen stood or is that a float problem?
symonh2000
PostPosted: 19:59 - 12 Jul 2012    Post subject: Reply with quote
It is probably the float needle sticking.
You are lucky the engine didn't fire otherwse you would be looking at a bent conrod, plus other damage.
Just had a look and I am not sure if they did a Haynes manual, however the principle or rebuilding is pretty much the same on any 2 stroke single.
lihp
PostPosted: 20:00 - 12 Jul 2012    Post subject: Reply with quote
If your crank case is full of fuel I'd say your rings are pretty shagged Laughing
russell210276
PostPosted: 20:34 - 12 Jul 2012    Post subject: Reply with quote
found the stupid problem after looking closley and thinking about it something is missing????
the fecking reed valve
wen i sent the engine to be rebored they removed all the bits and gave me everything back in a box so not thinking and this is how much of a newbie i am to 2 strokes no reed valve Embarassed Embarassed Embarassed i gonna ring them see if they still have it which is a long shot was over 2 weeks ago since the rebore Embarassed
MaybeGuy
PostPosted: 20:35 - 12 Jul 2012    Post subject: Reply with quote
No, you're mistaking seals for bearings. It's a single remember.
The last post was made 13 years, 249 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.20 Sec - Server Load: 0.18 - MySQL Queries: 13 - Page Size: 65.87 Kb
