| lamnea |
 lamnea Two Stroke Sniffer
| at106 |
 at106 Brolly Dolly
| lamnea |
| darthbuttchin |
 darthbuttchin Scooby Slapper
| Boxing |
 Boxing World Chat Champion
| lamnea |
| at106 |
 at106 Brolly Dolly
 Posted: 19:29 - 08 Jul 2012 Post subject: |
The spark plug colour looks ok, but it does sound as though the choke is stuck on. From a bit of searching it appears this bike has an auto choke which can fail. On the carb there will be a black box with wires coming off of it which will go somewhere into the loom.
You can test the choke by following this guide https://www.pedparts.co.uk/blog/automatic-choke-unit-50cc-mopeds
But it is easier to remove the choke, connect its wires directly to the battery see if the plunger extends, then disconnect it leave it for 5 minutes and see if it retracts.
If the choke has failed its easier to replace it with a manual one  |
| baldy |
 baldy World Chat Champion
| lamnea |
| U_W v2.0 |
 U_W v2.0 World Chat Champion
| at106 |
 at106 Brolly Dolly
 Posted: 18:42 - 09 Jul 2012 Post subject: |
| lamnea wrote: | Okay so the choke is now off the bike, i am going to go about testing it tonight.
Some points,
When i had the u bracket off and ran the bike, if i were to push abit on the choke the bike ran correctly again.
However taking the choke tu just after the bike had been running it did seem to have extended, and then letting it cool it does seem to have retracted also? So say it is working, could it still be causing the issues? |
If when you push the choke unit down the bike runs ok, then it probably means the choke wasnt fitted or seated properly. On the outside of the choke unit i believe there is an o ring is this damaged? Also is where the choke seats within the carb clean, and has the u bracket been bent out of shape?
If everything checks out ok, i would refit the choke unit, making sure you push it down firmly, fit the bracket and run the bike and see if it runs ok. |
| lamnea |
 Posted: 19:37 - 09 Jul 2012 Post subject: |
The o ring its self is not damaged, and the bracket is not bent.
However the area where the choke seats is very dirty with black grease, the o ring and the are around it is also covered in it also. Everything will be cleaned and re fitted, is carb cleaner appropriate to do so? ____________________ Honda Vision Ne50mff! |
| at106 |
 at106 Brolly Dolly
 Posted: 08:38 - 10 Jul 2012 Post subject: |
| lamnea wrote: |
However the area where the choke seats is very dirty with black grease, the o ring and the are around it is also covered in it also. Everything will be cleaned and re fitted, is carb cleaner appropriate to do so? |
Yeah carb cleaner will be fine  |
| lamnea |
 Posted: 11:49 - 12 Jul 2012 Post subject: |
Okay so some updates,
Auto choke all cleaned and where it seats all cleaned and re fitted. Still no luck. However if i pull it up a little or to the left the bike runs as normal, so it must have something to do with the choke.
Tested the auto choke again to be sure and it extends / retracts as it should with no issues.
Any ideas ????
To add the the list of things to repair the spring in the rear brake has decided not to work! Awesome ____________________ Honda Vision Ne50mff! |
| lamnea |
| at106 |
 at106 Brolly Dolly
| lamnea |
| U_W v2.0 |
| lamnea |
| U_W v2.0 |
| at106 |
 at106 Brolly Dolly
The last post was made 13 years, 251 days ago. Instead of replying here, would creating a new thread be more useful? |
