Bridgestone 092 Tyre Defect = MOT Failure!
porndoguk
PostPosted: 21:26 - 21 Jul 2012    Post subject: Bridgestone 092 Tyre Defect = MOT Failure! Reply with quote
i dotn post often im a lurker and chip in with the odd bit of rubbish here and there however i thought id share this with the masses to get a general consesus on the issue in hand
well the NC30 went in for MOT today and i thought all was well BUT,
he noticed the cords were coming out the tyre he said, i thought WTF its only done a few 1000s miles its well within the limit (4mm) well it turns out that there are cords are in the surface of the tyre in one small bit enough for him to fail it apparently, a cord was pulled out where the line is. i assume it could be just a few loose fibres not really cause for panic or concern that were in the mould, but its also 5mm near the compound change on the side walls see the dotted line of chalk i did,
pics attached, ps sorry for the repetative images its just different angles and light hopefully to catch the best the eye can see, this has to be seen by the eye really.
https://i107.photobucket.com/albums/m302/porndoguk/temporary-54.jpg
https://i107.photobucket.com/albums/m302/porndoguk/temporary-55.jpg
https://i107.photobucket.com/albums/m302/porndoguk/temporary-56.jpg
https://i107.photobucket.com/albums/m302/porndoguk/temporary-57.jpg
https://i107.photobucket.com/albums/m302/porndoguk/temporary-58.jpg
https://i107.photobucket.com/albums/m302/porndoguk/temporary-59.jpg
https://i107.photobucket.com/albums/m302/porndoguk/temporary-60.jpg
https://i107.photobucket.com/albums/m302/porndoguk/temporary-61.jpg
https://i107.photobucket.com/albums/m302/porndoguk/temporary-62.jpg
https://i107.photobucket.com/albums/m302/porndoguk/temporary-63.jpg
also the advisorys were:
The rear brake being wank a common thing for the NC, despite a FULL overhaul new juice, seals and pistons and new pads and goodridge hose and master cylinder overhauls i really cannot do anymore?
The front brake pulsating under heavy load, i put that down to the smaller NC30 Master Cylinder and CBR600RR calipers
and STIFF steering - ill put that down to the steering damper.
Frost
PostPosted: 21:52 - 21 Jul 2012    Post subject: Reply with quote
stiff steering might be over tightened head bearings or something catching somewhere. take the damper off and try it.
Rear brake will be air in the line.
Pulsating lever or due to warped / uneven discs not really cylinder size.
Is the cord removable from the tire? If not I'd be sending that tire back to quality control for a refund.
PostPosted: 22:44 - 21 Jul 2012    Post subject: Reply with quote
Or wheel bearings going for the brake. Shouldn't be anything to do with ratios or types of brake.
Hyaon
PostPosted: 22:55 - 21 Jul 2012    Post subject: Reply with quote
Saddest tyre I've ever seen...poor mite.
https://www.bikechatforums.com/download.php?id=84930
Mod2 Passed 30/03/2011!
CBF125>GSF650 Bandit K8>B-King 2008+R1 2002
sickpup
Old Timer
PostPosted: 00:38 - 22 Jul 2012    Post subject: Reply with quote
The tyre isn't defective, it has a deep slash that has severed and exposed the cords. I recommend you change it asap and don't ride on it.
symonh2000
PostPosted: 09:18 - 22 Jul 2012    Post subject: Reply with quote
That is what I thought at first, but it also looks like it could have a stray piece of cord embedded in the rubber near the surface which has exposed itself due to wear.
It is difficult to see how deep the slash is on the photo.
Four strokes is two strokes too many.
DrDonnyBrago
PostPosted: 09:26 - 22 Jul 2012    Post subject: Reply with quote
I'm not convinced. In the photo below, you can see what looks like the pattern of a twisted bit of cord cast into the rubber. As if a bit of stray cord was embedded into the rubber during manufacture and has since been pulled out, leaving a castedrecess.
sickpup
Old Timer
PostPosted: 10:01 - 22 Jul 2012    Post subject: Reply with quote
So how deep is the slash? I estimate about 5mm.
I think it would be easier to tell with the tyre off the rim.
It's not really possible to have a stray cord on the surface. The cords are in the carcass with the tread a separate skin of rubber overlaid so there are in fact no cords in the tread. If it was a stray thread from the carcass it would still be under the tread and could only get out if the slash went down to the carcass.
DrDonnyBrago
PostPosted: 10:17 - 22 Jul 2012    Post subject: Reply with quote
I think he means, and what I think it looks like, is a stray cord (not from that tyre) from the factory seems to have found it's way into the rubber overlay prior to moulding and vulcanisation. Of course a big gash could also chuck up a cord from the carcass, but it doesn't look like that has happened.
i.e. The long strip of soft rubber that is wound around the carcass before the tyre is moulded/heated seems to have had a bit of cord in it.
PostPosted: 12:43 - 22 Jul 2012    Post subject: Reply with quote
Agree
It does look rather like an embedded bit of cord. I would have thought if the cut was deep enough to cut the cord and allow a strand to the tyre surface it would have deflated or blown out.
Triumph Trophy Launch Edition
Barnaby This post is not being displayed because the poster is banned. Unhide this post / all posts.
sickpup
Old Timer
PostPosted: 13:26 - 22 Jul 2012    Post subject: Reply with quote
Polarbear wrote:
Agree
The it will pull out with a pair of pliers. Highly unlikey.
DrDonnyBrago
PostPosted: 16:18 - 22 Jul 2012    Post subject: Reply with quote
Barnaby wrote:
Bridgestone can't make tyres
Correct:
https://topsportracing.com/wp-content/uploads/2012/07/Rossis-tire-at-Assen.jpg
porndoguk
PostPosted: 18:32 - 22 Jul 2012    Post subject: Reply with quote
Thanks for the comments,
As i said above it really needs to be seen by the eye, it isnt a GASH as much as i love to hear and say it on this occasion it is not, see the loose bits of rubber that is from where a piece of cord was removed, hence the loose bits where it is spun at the factory.
The groove isn't straight, it also isnt a full groove there are peaks and lows, i inflated the tyre to 60psi with my compressor to see if the GASH would expand it didnt.
I will after ive heard from bridgestone, depending on there reply cut away slowly at the surface with my dremmel to show this is a fuck up.
yes im best off taking the tyre off again to prove it isnt a GASH as ill be able to bend and manipulate the tyre
AlexW
PostPosted: 18:59 - 22 Jul 2012    Post subject: Reply with quote
I would imagine if bridgestone take it seriously, they would want you to remove the tyre and send it to them so they can check it, rather than go on what somebody with a dremel is saying at the end of the phone.
Be good to know the outcome though!
porndoguk
PostPosted: 19:21 - 22 Jul 2012    Post subject: Reply with quote
i get what your saying, the dremmel operation was only if bridgestone told me to do one Wink
i would of course photo all of it to prove this is a defect,
ive eyed up a set of 090's for 169.40 delivered, its a shame the NC has a 18" rear as im stuck to one brand with the bike
c-m
PostPosted: 20:58 - 22 Jul 2012    Post subject: Reply with quote
This is exactly what happened to my Diablo Super Corsa front back in Split. I still rode it to Belgium before it blew.
knowing that now I'd be changing that tyre asap. You MOT guy is correct.
Motorcycle headlight bulbs and HIDs
Blogging about my bike and trips
https://ridershandbook.com/
porndoguk
PostPosted: 22:12 - 22 Jul 2012    Post subject: Reply with quote
iooi
PostPosted: 09:13 - 23 Jul 2012    Post subject: Reply with quote
I would get the wheel off. Then ring bridgestone and ask which local dealer would be best to take this too, for them to look at.
Failing that take it back to the dealer that fitted it.
Clearly you don't want to be riding on that tyre or taking anything to it, that will allow bridgestone a easy out.
Andy_Pagin
PostPosted: 10:58 - 23 Jul 2012    Post subject: Reply with quote
+1 to above post. Contact Bridgestone, they'd most likely be keen to know about a manufacturing fault in a tyre. I've reported faulty goods directly to manufacturers before (albeit just supermarket shopping stuff) and quite often got a nice little prezzie or two back in gratitude.
porndoguk
PostPosted: 07:01 - 24 Jul 2012    Post subject: Reply with quote
I spoke to a nice chap at bridgestone called gary, there policy seems a bit shit tbh, and in interest to PR this to is shit, i was told IF it is faulty they will refund a percentage of the tyre down to the usage, i worked out ive done 1590miles since fitted, no burn outs, heavy braking etc so whatever wear its had is beyond me, ive ordered a set of 090s and will get them on as soon as they are here, i then have to send it back to bridgestone be butchered.
CaNsA
PostPosted: 07:26 - 24 Jul 2012    Post subject: Reply with quote
Why did you stick with bridgestone rubber?
Michelin and Dunlop are far better......
UnspeedySam
PostPosted: 07:44 - 24 Jul 2012    Post subject: Reply with quote
Awkward 18" wheel sizes. My bros has a similar problem which is why it runs bt45s.
iooi
PostPosted: 08:37 - 24 Jul 2012    Post subject: Reply with quote
Not always the case.
Diffrent bikes, diffrent people. Prefer diffrent rubber Thumbs Up
Crap policy by Bridgestone. You would think that if it was a manufacturing fault they would simply replace FOC. Not pussy foot around looking at how many mile it has done and then refunding that amount.
I would go back and ask to speek to someone higher and point out, had it have gone while riding they would be looking at a much larger payout....
As such as a good will gesture will they sort out a replacement and free fitting at a local dealer.
sickpup
Old Timer
PostPosted: 09:43 - 24 Jul 2012    Post subject: Reply with quote
That'll be why Michelin paid me out £2000 for a defective tyre then....
The last post was made 13 years, 211 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.67 - MySQL Queries: 13 - Page Size: 131.94 Kb
